No, which I hope its not internal. I'm checking for any exhaust leaks by the turbo, and inspecting the belts as well.JimBee wrote: 03 Aug 2018, 17:56 A bearing that is worn enough to cause a knocking sound should be dropping oil pressure. At idle is your oil pressure light coming on?
'98 V70 T5 Knocking sounds
Aphx02
- Year and Model: 1998 V70 T5
- Has thanked: 13 times
sventastic
- Year and Model: 1996 854R
- Been thanked: 6 times
I hope so too. I should have given more backstory, as I'd be rather surprised if yours does indeed have rod knock especially since the oil level is normal and it seems there weren't really any symptoms beforehand. Just odd that it sounds similar. My car ended up about 3L low on oil (unexpectedly burned over a regular oil interval) and began with what sounded like lifter tick, which turned into a knock.Aphx02 wrote: 05 Aug 2018, 09:23 Very similar, but I hope its not that. I'm starting first to check for any exhaust leaks by the turbo, checking my belts, and changing my oil to see for any sediments left behind from a worn bearing.
1996 854R | M56H | 16T | 274k | BC, Canada
precopster
- Year and Model: Lots
- Been thanked: 128 times
I had rod knock on my original 2001 T5 engine and I ran it until the rod smashed out through the block-no oil pressure lights at all. I hope it isn't a rod or main bearing
Aphx02
Update: So I left it running for about 15 minutes, and afterwards, that knocking sound is not heard anymore. Could it be exhaust related that it expands possibly at the exhaust manifold? I've started though having a plan b, c and d. Plan b, buy a used engine. Plan c, have the engine rebuilt or plan d, do it myself, and that would entail cams/ported head, and may get out of hand. I used to road race in 85 Corolla GTS and a 02 SER Spec-V, both vehicles fully built, engine and suspension. The Wagon is my next 'road wagon', at Willow Springs.
- RickHaleParker
- Been thanked: 978 times
"Could it be exhaust related that it expands possibly at the exhaust manifold?"
Yes it is possible. Build a smoke machine, blow smoke up it's waste pipe, see where the smoke comes out.
Active
Past
Past
Aphx02
Update: So that knocking has definitely gone once its warmed up and running. I've already went ahead to purchase an exhaust manifold gasket along with a V70R manifold...Found a couple under 120.00 so I'm purchasing one and I already catalogued cams, piston, block for my stage 3. Here's the vid:
- Has thanked: 2199 times
I have heard of some owners complaining of cracked exhaust manifolds. Good luck!
Should have added, you should also check the flex down pipe as they also break with age.
- 7098 Views
Last post by dacson
- 1002 Views
Last post by CIK7
- 1151 Views
Last post by polskamafia mjl
- 1623 Views
Last post by kcodyjr
- 1884 Views
Last post by bluebossa
