2000 C70 6843481 M56 Driveshaft seal Topic is solved
subzerocarfanatic
Year and Model: 2000 Volvo C70 HT
Has thanked: 75 times
Been thanked: 10 times
Post by subzerocarfanatic »
scot850 wrote: 20 Apr 2020, 13:52 It is possibly the rear main seal or could be a turbo oil pipe. Both common issues. and oil ends up where you see it.
For rear main seal, try one of the oil seal repair fluids. Can't remember the number but ATP makes one. Blue devil also do one. I have used both and they worked.
Oil lines to turbo are a pain, but a common issue.
My question is why do they only leak when the car has been driven,it can sit and idle for 30 minutes and does not leak a drop but when I drive it then come back and look under the car it is on top of the drive shaft and then slung everywhere.
subzerocarfanatic
subzerocarfanatic wrote: 22 Apr 2020, 09:44
The ones you are referring to,the turbo lines,they have the double copper compression washer/gasket correct/ I just got them in yesterday,i ordered them last week in case they were leaking,it does not look like they are leaking at all but it has to come from somewhere and why does the oil dipstick still show full if it is oil that's leaking?
Has thanked: 1609 times
Been thanked: 4065 times
The oil drain line has a gasket on the bottom of the turbo, and a rubber oRing on the oil pan/block (Just above the oil pan)
When mine went.....it got oil all over the driveshaaft which sprays it all over the rear (right) of the engine
:D
links
viewtopic.php?f=1&t=89166&p=503296#p503296
