I assume you mean #43 and #50? (Not #53 and #50)Cookeh wrote: 01 Dec 2020, 07:08 I was under the impression #53 and #50 are the same, but #48 differs. Being wrong here is definitely a good thing, though, as it's one less thing to consider.
Grab all of the fasteners for the big mid-brace. All of the bolts at the front (the rear SF mount) are longer than the standard bits.
The front V-brace will require adding some sort of threaded inserts to mount it to the subframe. Rivnuts are an option, if you have the proper tool.
Go for the Delrin SF bushings.
