Driver Side Wheel Bearing Noise Diagnosis
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
I found the rubber damper on after market ones too. Genuine have a sticker on the inner CV joint, may get covered with dirt so rub a little. Genuine also have very thick clamps. If the aftermarket one is not vibrating and the boots are fine , don't replace it.
Has thanked: 1610 times
Been thanked: 4065 times
You can usually diagnose a wheel bearing over an axle by side-to- side swerving. A bad wheel bearing noise will increase when you turn away from it, and decrease when you to turn to it.
Also CVS.....thiunkity thunkity Cronkite
Wheel bearings......grisly growls whirrry*
*ISO 14000 approved terms
If you live in IA, wheel bearings never go. It’s the potato grease on the roads
a3inverter
Year and Model: 2006 V70
Been thanked: 9 times
Post by a3inverter »
The old axle turns out to be a “GSP”. I’ll save it as it seems fine other than the hole in the boot. Almost certain the noise was from the wheel bearing.
