If I pull the intake manifold can I see the valve stems enough to determine they’re status?
Yes, you can see the guides and back of the valves through the ports. Hope you are ok!
06 s60 no valve movement
stephansvolvo
- Year and Model: V70 GLT 1998
- Has thanked: 21 times
- Been thanked: 3 times
Seems way easier than pulling the head again!abscate wrote: 03 Aug 2021, 04:46 If I pull the intake manifold can I see the valve stems enough to determine they’re status?
This went from unsolved to solved back to unsolved.
Stephan
84 240GL my first(sold)
88 240GL(timing belt killed it)
98 S70 GLT
73 IH Scout ii
98 S70 GLT
73 IH Scout ii
- jonesg
- Year and Model: 2004 V70
- Has thanked: 73 times
- Been thanked: 534 times
You can put each cyl at TDC and apply 15 psi air to the plug hole.
Low pressure is to prevent the engine rotating, I do this on my briggs engine in a tractor, you can hear it.
- 2129 Views
- 1368 Views
- 14 Replies
- 2682 Views
Last post by mecheng
- 1771 Views
Last post by Sommerfeldt
- 1879 Views
Last post by rspi
