96 850 Turbo Wagon: what other tires can I mount on my 16" alloy rims?
insession
Year and Model: 1996 850
Been thanked: 2 times
Post by insession »
Thanks Blackbart for the tirerack reminder. I have a $150 credit at discounttirezone.com, so am likely going to use them
insession
Post by insession »
Thanks 850oldschool ;-) Yeah, I've had Nokians twice before, and have found nothing beats them if there's water, snow, or ice. In fact although I live in sunny San Diego, I'm looking at their WR G4 - originally an SUV tire but Nokian makes them for sedans as well. Interesting to hear you're the first one who reports modest chafing with the 55's...
Has thanked: 311 times
Been thanked: 817 times
Post by erikv11 »
I've got 205/55/16's on my 95 850 and no chafing.
850oldschool
Year and Model: 1996 850 NA
Been thanked: 45 times
Post by 850oldschool »
I had aftermarket control arms on, so the steering stops might have been a little different from OEM. The extra fuel economy was welcome, and I made a chart for the speedo correction factors. It all worked out pretty well, but the steering felt a bit more direct when I went back to the 50 series.
insession
Post by insession »
Thanks 850oldschool - my mileage strangely actually dropped by a fair bit last I replaced rotor, cap, plugs, and wiring harness. - I had expected the opposite. Surprised .5 up in wheel height affects the economy that much!
Has thanked: 2200 times
Been thanked: 1852 times
Shouldn't affect mileage much if at all. If mileage changed after changing the ignition parts then something during the fitting of the parts or the type/brand of parts used is out of whack.
misha
Has thanked: 155 times
Been thanked: 432 times
Post by misha »
insession wrote: 15 Dec 2021, 19:35 ...Interesting to hear you're the first one who reports modest chafing with the 55's...
There will be some minor chafing on full lock on the inner protective plastic inside the fender IF steering stops(plastic plates) on control arms are worn.
Or....if the wheels have the wrong ET.
43 is factory offset for p80.
Anything over 43....49 for example(like wheels from s80) will lightly rub on the front but ONLY on full lock.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
insession
Post by insession »
Thanks scot850 - yes, I thought so too. Used a high-quality aftermarket kit from fcpeuro, and am thinking that those components can't really be 'wrongly' installed, they either work or don't, and was dismayed that I lost about 2mpg in economy ;-)
insession
Post by insession »
Would any of you very knowledgeable fellows know how to help me ID my type? 2.3T or 2.3T-5R? Seems to make a diff when looking at tire options here: https://www.wheel-size.com/size/volvo/850/1996/
misha
Post by misha »
insession wrote: 17 Dec 2021, 18:04 Thanks scot850 - yes, I thought so too. Used a high-quality aftermarket kit from fcpeuro, and am thinking that those components can't really be 'wrongly' installed, they either work or don't, and was dismayed that I lost about 2mpg in economy ;-)
Spark plug gap is critical on turbo engines...it must have proper gap.
Unless you used OE Volvo spark plugs for turbo engine,you need to re-set the gap on new spark plugs since all aftermarket have larger gap.
Cap & rotor must be Bosch,spark plug wires...ONLY Bougicord.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
