I cant get the valve stem seals out.
2001 - 2007 V70
2001 - 2009 S60
2003 - 2007 S60 R
2004 - 2007 V70 R
02V70
Year and Model: 2002 V70XC
Has thanked: 53 times
Been thanked: 40 times
Re: I cant get the valve stem seals out.
Post by 02V70 »
I ended up using these and put tape on it do avoid scratching the head.
2002 v70 X/C 288k miles
ibs740
Year and Model: V70 2004
Been thanked: 2 times
Post by ibs740 »
It wasn't on a V70 but for removing motorcycle valve seals.
Take a flat screwdriver you don't like that's maybe 1/4"ish wide, get a torch, a small propane one will do.
Heat the tip going back about an inch, bend the tip into a short hook a little tighter than 90 deg.
and let it cool. You now have a powerful pull/pry tool.
I like the screw idea, so if you have a slidehammer that would work also. A very adaptable tool
especially if you have a welder.
good luck
