Cannot get crank pulley off
- Been thanked: 4071 times
There is a chassis break when the direction of setting the tensioner reverses, so you need your engine number to get the right info.
iamhives
- Year and Model: 2018 V90 T5 R design
- Has thanked: 1 time
- Been thanked: 6 times
Chassis number is 570418 and engine code is 3861511. Its actually a 2006 (I'm getting my V70's mixed up!) so it is the newer tensioner (correct me if I'm wrong)
The job is basically done, I just want to check I've set the timing belt tensioner correctly. Its a little confusing between teh two tensioner types since its not clear in all of the videos I've seen what year and which tensioner is being used. It sounds like the two tensiones loosen/tighten and loose in different directions? Can someone confirm that
Old tensioner (before engine number 3188689), loosen is clockwise and tighten is anticlock
New tensioner (after engine 3188689) loosen is anticlockwise and tighten is clockwise.
Also for the newer tensioner what is the position of the hex hole to start and when tensioned. Currently with the tensioner in what I think is the right position for medium tension the hex bolt hole seems to be in about 2 o/clock position. I started with the hex hole at ~ 11 o'clock turned clockwise to about 2 o'clock. Is this correct?
You start with the tensioner at 10 o/c
You overtighten the belt, depending on engine number, then loosen it back to the correct tension position
Tighten the timing belt:
There are two variants of the belt tensioner.
From (sic, should be up to ). engine number 3188688 the eccentric must be turned anticlockwise to tighten the belt.
From engine number 3188689 the eccentric must be turned clockwise to tension the belt.
turn the crankshaft clockwise carefully until the camshaft belt is tensioned. The belt should be tight between the intake camshaft pulley, idler pulley and crankshaft.
hold the center screw on the belt tensioner in position and turn the eccentric on the belt tensioner clockwise/anticlockwise, depending on the variant, until the tensioner's needle passes the marked position.
Then turn the eccentric back so that the indicator reaches the marked position in the center of the window.
Secure the eccentric and tighten the center screw to 20 Nm .
Check that the needle is in the correct position.
iamhives
Thanks for everyones help. The job is done and the car started up and ran fine. No vibration of the tensioner and the belts ran straight and true. Really wasn't that bad. The worst parts for me were the easier ones - getting the timing belt cover under the crank pulley back in the right place, cleaning the old gasket off and trying and failing to get the crank pulley off - unnecessary as it turns out. Seemed to run smoother and quieter than before (maybe belt and tensioner noise reduced). As it was, everyhting I replaced was in OK condition and it just seems that the WP gasket was leaking.
Just for the record and to help people who read this thread in the future, I think Abscate, in your post above there is a slight typo and the first 'From' should be 'up to'. Anyway, with the new tensioner (roughly 2005 and up I believe), tightening is clockwise .
Thanks for catching that typo…ill let Volvo know!
I’ve heard that works, Feld m but that is awful on your starter, Bendix, flywheel teeth. All horribly expensive stuff to fix if breaks.
- jonesg
- Year and Model: 2004 V70
- Has thanked: 73 times
- Been thanked: 534 times
it worked on my 740 , disconnecting the ignition was much simpler with the distributor right there.abscate wrote: 26 Apr 2022, 03:52 I’ve heard that works, Feld m but that is awful on your starter, Bendix, flywheel teeth. All horribly expensive stuff to fix if breaks.
A quick blip of the key is all it takes. It doesn't help when it comes to tightening.
- 1524 Views
Last post by XC70Rider
- 15 Replies
- 3641 Views
Last post by GreenMagicMan
- 3230 Views
- 2877 Views
Last post by lummert
- 21 Replies
- 10536 Views
Last post by GBS
