List your 850/S70/V70/XC70 parts failures, 1992-2000 only
Cactuslegs
- Year and Model: 2000 C70
Timing belt tensioner count as "timing belt"? That's what went out on my gf's c70, I didn't know anything about cars back then, we bent her valves =(
Xilikon
- Year and Model: 2000 V70 XC SE
With my car, current broken things to fix :
-Blower motor
-Fuel pump seal
-Rear wiper assembly (motor working fine but shaft where the wiper arm attach is locked due to salt)
-Blower motor
-Fuel pump seal
2000 V70 XC SE with 150,000 miles, still going great !
- misha
- Has thanked: 155 times
- Been thanked: 432 times
O2 sensors
Maf sensor
Sas valve
Battery cables
Abs/tracs module
Fuel pump
Upper torque mount/bushing
Bendix
Fuel door lock
Thermostat
Front wheel bearings
Glovebox lock
Radiator
Maf sensor
Sas valve
Battery cables
Abs/tracs module
Fuel pump
Bendix
Fuel door lock
Thermostat
Glovebox lock
Radiator
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
panchjanya
- Year and Model: V70, 2001
Hi
This is my 1st post. Just bought a 01 V70 T5 and the back seat, behind the passenger seat, (the larger one) refuses to fold down..the mechanical slider on the edge does show that red little thing popping up but it does not fold..any ideas ?
Wrenchinjoe
- Year and Model: V70 1999
Some of these are simply maintenance items, but they still needed replacement on our car:
- rear wiper washer motor
- rear brake calipers
- tailgate attachment clips
- ball joints & control arm bushings
- gas cap door hinge
- shifter button
- headlight wiper motors (not replaced)
- driver's seat heater (has a nice charred spot)
- dash to firewall mounts cracked
- headliner delaminating
- throttle body (fixed under warranty)
- cv boots
- O2 sensors
- ABS module (thanks Matty Moo)
- struts
... to be continued
- shifter button
- cv boots
- O2 sensors
- struts
... to be continued
Base model V70, Silver Sand Metallic, vinyl seats, 132K miles, IPD HD spring seats
I don't really understand the point of this poll (even though I took it). My car is a 99 and has about 200k miles. I would consider most of this list as normal stuff that would wear out and need to be replaced on most cars over the last 11-19 years. Some of this is just normal maintenance.
allnewgene
- Year and Model: v70 xc, 1998
i thought I had a charging system problem, but found the courtesy lights on the door were not turning off when the door was closed. Had to put my eye right on the door crack to see it. I have now removed it. Same with the courtesy lights near the feet on both sides. Some courtesy!
Xilikon
Currently in a indy shop. Casualties :
starter (now rebuilt)
AC compressor (old was so seized that it caused the death of the starter from what my indy told me).
The good thing is that with the new ac compressor, I can finally have a working AC soon.
- 1609 Views
Last post by foggydogg
- 36 Replies
- 7970 Views
Last post by bmdubya1198
- 18 Replies
- 8671 Views
Last post by rspi
- 1374 Views
Last post by clarkerussell
- 23 Replies
- 6268 Views
Last post by oragex
