Has the link to this odometer fix been removed?
Thanks.
Amazingly well documented Odometer Fix
How to Fix the Odometer on your Volvo 850
Old Bakelite
- Year and Model: 1997 850 T5
1997 850 T5 Wagon 64k (Hers!)
RIP - 1997 850 GLT Wagon 167k...up in smoke.
- Has thanked: 2864 times
- Been thanked: 1332 times
Thanks Klaus. Ooof, that's embarassing.
I fixed the head post's link.
Old Bakelite
Thanks Klaus and Matthew!
Old Bakelite
OK, last thing before I get started is knowing the actual mileage so I can put it right on the odo...but now I do not know how to do that. Is it possible from the OBD? Do I have to go to Volvo dealer only? Or maybe it is not possible at all on 97 year model?
Thanks for advice.
Thanks for advice.
- Year and Model: Many Volvos
- Been thanked: 76 times
It is pretty much a dealer only thing after '95. An independent shop that has a Volvo scan tool can also do it. The problem is that most of them, dealer service departments included, don't know how to find it in the menu. It must be buried pretty deep in the menu tree.Old Bakelite wrote:OK, last thing before I get started is knowing the actual mileage so I can put it right on the odo...but now I do not know how to do that. Is it possible from the OBD? Do I have to go to Volvo dealer only? Or maybe it is not possible at all on 97 year model?
Thanks for advice.
Old Bakelite
Thank goodness for forums like these as the "specialists" obviously can not be trusted
Hi. After replacing the the gear and putting back the cluster, I realized when driving in the dark, that the 3rd in a row from left to right light behind the cluster doesnt work (even though it worked before), and the speedo needle is way more faded (has minimum light) than the others. Also, the tracs light doesnt come on, although I swapped it with another one, it still doesnt go on. Any thoughts/help will be appreciated.
I replace all of the lamps, working or not, when I repair the gear anymore. The amount of jostling getting the cluster in and out will break the filament on used bulbs about half of the time. I had similar issues when I changed the gear on my first 850.
The main lamps are easy, any auto parts store will have them, but the smaller lamps are tougher to find. I think Robert (member name RSPI) sells the warning lights for considerably less than a dealership.
- dosbricks
- Year and Model: '96 855, '98 S70
- Been thanked: 4 times
tzanis, I'm not sure if your '97 has an option to reset your service reminder light, but my '96 did not, so I pulled that bulb when I replaced my odo. gear. Just a thought.
- 2022 Views
Last post by Ozark Lee
- 14 Replies
- 2299 Views
Last post by BlackBart
- 14 Replies
- 6884 Views
Last post by oragex
- 2894 Views
Last post by polskamafia mjl
- 2905 Views
Last post by joe_pinehill
