When you say " super16T ", is that the set up with the 11 blade turbine ?
More power out of b5254t(this has been done too many times I know) Topic is solved
- Sveedy
- Has thanked: 417 times
- Been thanked: 457 times
Re: More power out of b5254t(this has been done too many times I know)
1999 V70 GLT
1999 V70 GLT
- Goupil
- Year and Model: 98' V70 LPT
- Has thanked: 30 times
- Been thanked: 112 times
Nope, that's why it took us (me and the tuner, aaron from Vast) and the engine by surprise.
It's an old stock aftermarket turbo, the CHRA has been replaced by a 300$ OE type one and the hot side is an angled flange from a volvo 13t (not even the bigger one).
Nothing in this was supposed to perform more than any oem 16T, yet it does
1998 Volvo V70 B5254T M56
1994 Volvo 945 B230FT M90
1985 Volvo 240 B230E
Petskoi
- Year and Model: 1997 V70 awd
NiceGoupil wrote: ↑25 Aug 2022, 13:58the bent rods were from me not looking at the data, doing a pull for logs, ran out of MAF unexpectedly so it was running super lean![]()
The second time it started knocking makes no sense, there isnt anything wrong in the datalogI'm replacing the knock sensors and installing an oil pressure gauge this time (+ some H beam rods and new bearings)
Petskoi
Well it is true, that a 13t flows actually better than even a 15g. I was counting some hp numbers with different psi's using the compressor maps for 13t, 15g, 16t etc. Thought I was counting wrong, checked many times then gave up and used an online calculator and it gave me same numbersGoupil wrote: ↑25 Aug 2022, 14:43Nope, that's why it took us (me and the tuner, aaron from Vast) and the engine by surprise.
Nothing in this was supposed to perform more than any oem 16T, yet it does![]()
Petskoi
I was just wondering is it safe to drive the car to the tuning shop, after installing bigger injectors, the new turbo and the japanifold? The stock tune should limit the boost so that it doesnt lean out right?
- Goupil
I would say it will probably run richer more than anything due to the bigger injectors. Is it a long drive? If you can, keep it out of boost as much as you can and it should be fine
