850 Bumper and trim restoration
- foggydogg
- Has thanked: 83 times
- Been thanked: 405 times
Do you plan on applying the Cerakote yourself ? If so let us know how that goes.
- Sveedy
- Has thanked: 445 times
- Been thanked: 479 times
I applied the Cerakote a day or two after I redyed them. Came out great. You have to be careful with that stuff. Don't keep going back over it; that will cause streaks. Just a smooth even coat and go over it as little as possible.foggydogg wrote: 16 Aug 2023, 06:47 Do you plan on applying the Cerakote yourself ? If so let us know how that goes.
1999 V70 GLT
1999 V70 GLT
- BlackBart
- Has thanked: 967 times
- Been thanked: 921 times
Sveedy, are the two bottles in your pic the same product, but one is turned 180 for the label?
- Sveedy
Two different colors from a different manufactures that are connected in a round about way, from what I can tell. The gray has a note on the bottle - " From the founder of Solution Finnish ". Same bottle and directions. So maybe a split-up of some sort between founders, and one got to keep the name Solution Finnish ?
" You better not make Black. "
" Fine. I'll make gray. And you can't have ANY of it. "
" Fine. I've got the name. "
Just guessing....
Just guessing....
1999 V70 GLT
1999 V70 GLT
- Sveedy
Re: the Cerakote; I think Solution Finnish also makes a sealer. I used the Cerakote because I had already bought it, figuring on just using that. I'm sure it would have been great, but I was worried that if I didn't do something about the stains first, that they would become permanent after sealing.
1999 V70 GLT
1999 V70 GLT
- Sveedy
Here you go Tim -
This is how it has stood up to the Arizona sun over 2 1/2 years. Not bad at all imho.
1999 V70 GLT
1999 V70 GLT
