List your 850/S70/V70/XC70 parts failures, 1992-2000 only
Locked
What's *failed* in your 850, S70, V70, XC70, C70 (1992-2000)
Timing belt
50
2%
Top engine mount bushing
262
10%
Thermostat
152
6%
Door check strap or hinge
183
7%
ABS module
285
11%
Rear main seal
62
2%
Wheel bearing
92
4%
AC evaporator
103
4%
ETM
46
2%
Battery cable
48
2%
Any keyless entry component
129
5%
Any interior switch
210
8%
Camshaft position sensor
48
2%
Fuel pump or relay
111
4%
Heater core/ blower / resistor
183
7%
AWD's driveshaft or bevel gear
43
2%
Power antenna
156
6%
Sway bar links
146
6%
Mass airflow sensor
126
5%
Air pump
67
3%
Glovebox lock
65
3%
Head gasket
32
1%
Total votes: 2599
januwan
Year and Model: 97 850 NA 209 K
Has thanked: 7 times
Been thanked: 3 times
Post by januwan »
odometer gear
abs module
ignition switch
air pump
that's it after 122K
for my second car VW I would need few pages
januwan
i hate my volvo
Year and Model: 2000 v70xc
Post by i hate my volvo »
wow i came to this post to have some light shed on what the future of ownership would be like. my ''friend'' convinced me to get a volvo after my exhibition of speed ticket jacked my audi s4 insurance through the roof because they were ''reliable'' . now i'm scared poopless. FOR SALE : 2000 V70XC - ONLY 115K, RUNS GREAT, RELIABLE! $4500/obo ...hahaa
Volgrrr
Year and Model: '95 T5 wagon
Post by Volgrrr »
jackwatch wrote:MMMM what comes to mind immediately.......
sporadic Central locking ( keep a spare key)
stupidly priced keyless lock button, on my third
Window switches- burn out, one smoldered
light switches - crumpled in my hand
head lights
tail lights
B+ Cable
Charging system (new battery every other February, thats right 1@2years)
drafts from all the doors
windows constantly going on and off track
Incredible wind noise at highway speeds, good thing the radio (FM) is good
loose dashboard rattling , that no one could confirm until after 4 years, now $3,000 repair thats not happening
ETM (yesterday) software fix ( around 2006) put me 4 months out of the warrentee period $1200
Temp Sensor, randomly on/off -> ultimately new radiator-> which fell out of the car 350 miles from home. (2 years ago)
Timing Belt , got that done yesterday too (~$750)
front struts, third set now.
gas milage never better than 20-22 mpg
engine EMF interference on the AM radio that goes away when you lock/unlock the doors once or twice.
hot air that comes out all over the place no matter where you dial it to go.
some kind of sticky organic gue on most plastic surfaces that can only be peeled off
when clean, dashboard surface that reflects off the windshield on sunny days obstructing the drivers view
rear hatch interior panel that keeps falling off
stupid front wheel splash guards that get ripped off when backing up in snow.
corosion of the silver coating on the (mag) wheels
brake shoe life of ~20,000 miles, and squeeling when not worn
sticking brake calipers
I'll let some one else speak now............
But apart from that - you're a contented, happy Volvo owner? :mrgreen:
There are only two types of car owners - those who own Volvos and those who wish they did.
volvomileage
Post by volvomileage »
fuel pump
fuelpump relay
fuel injection relay
master windows switch
radiator
engine mounts lower and upper
maf
abs pump
heater core
cam sensor $$$$$
temp sensor
front wiper motor
sunroof rusted and falling apart
odometer gear
fuel line a very bad and shitty surprise...
trunk latch
ignition switch
volvo 850 95 sedan non/turbo 185 k
xb corp
Year and Model: 855GT5 '96
Post by xb corp »
dash....
radiator (pin hole leaks)
other than that would be;
worn tires :lol:
worn off brake pads :roll:
"missing gas mystery" (losing 50liters for 450km)...hehehe.. :P
blown 3rd brake light bulb :idea:
squeeking rear plastic trims :evil:
'96 855GT5 324hp 386lb-ft
Nissan 16V turbo, HKS w/g, SS 2.5" d/p+FGK 3" exh, HKS Evo9 FMIC+2.5" piping, K&N, Apexi BOV, NA cams & t/b, portd head, 5 sub-injctrs, Mocal coolers, AMG 4pot 325mm, AVS 18", Bilstein B6/Vogtland
BEJinFbk
Year and Model: '98 V70 R
Has thanked: 94 times
Been thanked: 146 times
Post by BEJinFbk »
I can't believe that I completely forgot about the Lower Motor Mount! (Pass Side)
Clunky shifting, funny noises and my paranoid feelings of doom, despair and lack of fundage
(OMG, I gotta rebuild the tranny! Aggghhhh!!! )all went away when I fixed that one... 8)
EddieH
Year and Model: 1995 850
Post by EddieH »
After reading some of the posts of other items, I feel pretty fortunate to have only dealt with these items ( not in any order)
Evaporator, Lower engine mount (pass. side), alternator (twice in 18 months), radiator, water pump, rear camshaft seal, spring seats, driver side headlight, radio, too many bulbs to list over the years, headliner (does this count?), gas tank cracked at heat shield attach point (replaced by Volvo under recall), rear passenger door trim (driver side).
Issues I am facing at present- PCV system cleaning (probably replace whole system w/ one from FCP), Egr valve cleaning, vacuum line fittings deteriorated, Tranny flush and fill. I have a CEL that comes on every once in a while and the code 241 keeps popping up from the A2 bank. Hoping I'll get through emissions testing since my tags expire at the end of this month and replace the PCV system this summer along with the EGR valve.
Eddie
Georgeandkira
Year and Model: '07 V70 + '15 XC70
Has thanked: 80 times
Been thanked: 71 times
Post by Georgeandkira »
Hello, It's March 11th, 2010; is this post/poll still active? Sway bar links, an interior switch (master window), top engine mount, lower right engine mount, CTS (coolant temperature sensor), windshield washer level sensor. There's got to be a better way to conduct polls on these sites. Kira
MNCO1
Year and Model: 850 T-5 1997
Post by MNCO1 »
I think the poll is taken by checking boxes listed above, not by writing items out. I could be wrong.
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2862 times
Been thanked: 1332 times
Post by matthew1 »
^^^ True. Write-ins are for the items that didn't make the list.
Kira, you should see this (although not with these checked, unless you've had the exact same problems as I have).
Also -> Amazon link
Locked
