Just went out to the car to check if I had one and the PO had a sticker for the filter change but no date... Probably from years ago from the amount of crap in it.
When is the flap under it open? Is that the mix flap on the dash?
Installing 850 Cabin Air Filter
Installing 850, S70, V70, XC70 Cabin Air Filter
thecheat
- Year and Model: 1996 850 Turbo Wagon
Little followup here... I bought a Purolator brand cabin filter and it did not fit very well. It was made out of very stiff cardboard that wasn't cut very precisely and was causing the edges to bow in. I had to trim some of the excess material at the corner joints and that helped a bit. I also took some folded cardboard from the box and reinforce the pleats either side (do on the side opposite the air flow) and that seems to be ok.
KlubMarcus
- Year and Model: V70 XC, 1998
This thread was so useful when I replaced the cabin air filter for my 1998 Volvo V70 XC.
Here are the pictures.
KlubMarcus
Same experience at my end. I picked up the Purolator because I wanted to change my old one that afternoon. Purolator cabin air filters definitely do not fit the 1998 V70 series. Volvo OEM definitely fits, so it is the most likely choice after next year's pollen season. Don't know about the fit of Fram's offering.thecheat wrote:Little followup here... I bought a Purolator brand cabin filter and it did not fit very well. It was made out of very stiff cardboard that wasn't cut very precisely and was causing the edges to bow in. I had to trim some of the excess material at the corner joints and that helped a bit. I also took some folded cardboard from the box and reinforce the pleats either side (do on the side opposite the air flow) and that seems to be ok.
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
My video version:
anmartin44
- Year and Model: 1994 850 n/a
- Has thanked: 2 times
- Been thanked: 2 times
Here's the filter from my dads 98 v70 with 132k miles. Pretty sure it was original. It was so clogged the blower would squeal at higher speeds and the defrost was quite ineffective.
1994 850 na green 187k on body, 275k on motor(backwards?), unrestricted airbox, 960 TB, persus wheels, Lowered, IPD poly upper and trans mounts.
1974 144 k-jet m40 satin black, 250k on body, 25k on rebuilt motor(running...usually)
- Has thanked: 2856 times
- Been thanked: 1332 times
anmartin44
that is terrible. Good thing you checked it.
The cabin air filter is the most obscure item in the list of Volvo service items. I'd bet more 850 owners lubricate the antenna mast as per the owner's manual then check/change cabin air filter.
Heck, I'd bet more P80 owners change the transmission fluid -- which is decidedly not a consumable/replaceable according to the Volvo service documentation back then.
- rspi
Contact rspi..
Nah, that one isn't original, but bet this one is...
mercuric
- Year and Model: 1997 850 T5
Great info, thank you. This is probably why it sounds like there's a few leafs stuck in my blower motor, looks like I can get the vacuum extension in there through the rain diverter to suck them out before installing a filter. Anyone try the OEM filter from the dealer? Is it effective at removing pollen? Allergies are kicking my behind this year
PlayGod
- Year and Model: 95 850 GLT Vagen 5sp
thank god the previous owners of my 850 GLT were maintenance freaks... I just replaced the cabin air filter. It was clogged with a lot of debris, but intact. Hopefully this will cure the problem of the A/C shutting off after 30 minutes or so.
- 1522 Views
Last post by 454cid
- 2101 Views
Last post by stephansvolvo
- 3872 Views
Last post by BEJinFbk
- 1289 Views
Last post by brunocerous
- 1543 Views
