1998 V70 XC AWD Random Misfire. P0300, P0302, P0304, P0305
Flufferstuff
- Year and Model: 1998 v70 xc awd
Hi everyone, I see that this thread is old but I have the same car; and I really love my car. I'm hoping people are still here because I have need of help now. It started vibrating a lot, and the check engine light is on. It threw four codes: p01-04. Now, after lots of work and parts it keeps throwing only p04. My son's been going through everything that can be replaced, etc. He hasn't replaced the ignition coil because he did that a year ago. Could it already be spent? What would make my car go through ignition coils so often? Is it possible that there is an underlying larger problem? We've done: spark plugs, spark plug wires, fuel filter, basically about $500.00 in parts.
My son wants to test the ignition coli but doesn't know how. Can anyone tell me how it's done? I've been without my car for 6 weeks so I would be very appreciative of any help.
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
I have no idea what a p04 code is but if you think it's a misfire, do a compression test to make sure you don't have a burnt valve.
as400jockey
- Year and Model: V70 T5, 2001
Fascinating. I have the same problem with my newly acquired 1998 S70 GLT with only 265k. It didn't do this when I was test driving for an hour. Started after I did some updates - plugs, wires, cap, rotor, air filter, etc. My guess is that my total gutting of the suspension had nothing to do with this
. And it was intermittent, although as of yesterday it happened every time I ran the car for a few miles. I carry the OBD with me to reset...
Compression is consistent, between 145 and 150 across the 5 cylinders. Fuel pressure checks out OK.
Today I swapped the ignition coil and MAF from my 97 850 wagon (only 245k) to see if the problem moves to the other car. And then I found this thread.
Sure enough, when I installed the new wires, I strung one of them right alongside the sensor wire you're referring to. I have cleaned up my mess and we'll see what happens.
2001 V70 T5; 1998 S70 Sport; 1998 S70 T5 (sold); 2002 S60 (sold); 1980 245 Wagon (crusher - rusted to smithereens); a few others... learned carb fixing at 10 year old on Dad's 1971 144 sedan.
v70xc
- Year and Model: V70XC AWD Turbo 1998
I am anxious to see if the moving of the wires is the fix. Please update.
The code is made up of a letter followed by four digits. Each one of these parts carries a specific meaning. The letter tells you what overall section of the car the code is coming from. P stands for the powertrain, the engine and transmission. B stands for the body. C stands for the chassis, including the brakes and suspension. U codes are for problems with the computer itself.
The first digit tells you whether the code is general or manufacturer specific. Most of the codes are universal and apply across manufacturers. These codes are standardized by the Society of automotive engineers. Manufacturers might add their own codes for their particular systems. Standardized codes have a 0 or 3 as their first digit, while manufacturer specific codes have a 1 or 2. The second digit further specifies which particular sub-system is affected.
P04 Auxillary Emissions Control
Are there not other digits following the #4?
The final digits signify the specific problem... if there are other digits.
Hope this helps
Hope this helps
1998 V70XC AWD Turbo
- 3433 Views
Last post by E Showell
- 1679 Views
Last post by RickHaleParker
- 1252 Views
Last post by blomkvist
- 12 Replies
- 2572 Views
- 11 Replies
- 2048 Views
Last post by greg850r
