Vacuum Elbow/Lines Question
alfatango1
Year and Model: 1998 V70
Has thanked: 2 times
Post by alfatango1 »
Thank you. Looks like routing it from the Flame Trap to the front of the engine to the manifold is the way to go.
alfatango1
Crazy, actually got that little sucker on with just two sets or long nosed pliers. One straight and one curved. Took two times though, gave up a few days ago but tried again this morning and got it by some miracle.
blackVolo
Year and Model: 2003 V70 2.4
Post by blackVolo »
I think I have to do this on my -98 2.5T AWD, it gives EFI 232 after 20 km in the city. One question, the picture does not show to me, where the other end the hose is supposed to go?
polskamafia mjl
Has thanked: 19 times
Been thanked: 21 times
Post by polskamafia mjl »
One end connects to the passenger side of the intake manifold and the other conencts to the PTC nipple on the pipe that runs from the airbox down to the turbo inlet.
It's line number 10 in the first picture in this thread: https://volvoforums.com/forum/volvo-850 ... ptc-26628/ .
blackVolo
Post by blackVolo »
I had the pcv system changed about 3 months ago. Isn't that hose a part of the pcv system? If so than I believe that this hose is changed. And if so ,would that mean that something else is the problem for my car?
EDIT:
in this picture it is hose with parts 14-11-10-13?
My mechanic assures me that it came with the pcv kit and he replaced it.
blackVolo
Post by blackVolo »
Took some photos. Here is connection to pcv nipple:
Vacuum connections at intake pcv
Here is the elbow:
Elbow pipe
Elbow pipe
And here is one lone tube that is not connected to anything, any idea where this should go?
Lone tube
Lone tube
Has thanked: 1609 times
Been thanked: 4064 times
Hei, blackVolo
That looks like on the connections to the airbox valve for the heater flap. There should be two pipes sticking out the rear (towards driver) of the air cleaner housing with two hoses/elbows on them on your car, if it does NOT have a turbo
You will need this working in Finland in December!
blackVolo
Post by blackVolo »
abscate wrote: 09 Dec 2019, 07:24 Hei, blackVolo
What does that mean, airbox valve heater flap? is it for heating up engine from cold, redirecting warm intake air from exhaust manifold? Or is it for cabin heater? Because cabin heater works fine, gives hot and cold as needed.
Yes, that is the one. Follow the silver fat hose from near the exhaust Manifold and it will lead to the 'motor' that opens/closes the valve to set the air intake to the right temperature.
blackVolo
Post by blackVolo »
It has a Turbo, if that helps for the diagnosis. Where should I connect the other end ( in the third picture). The lone tube just stands in between fan and throttle body.
