Volvo 850 Transmission Solenoid Replacement DIY
polskamafia mjl
- Has thanked: 19 times
- Been thanked: 21 times
In my case the car would drive fine until the transmission got warm. If I was lucky enough to be on the high way and just cruising everything was fine. But if I got stuck in traffic where a lot of shifting was required it would soon go into limp mode. The real indicator was reading the codes though.
ronhall102
- Year and Model: 95 GLT 850
Thanks a lot now I can do this on Monday early.
you are the best. so much you made me save.
Bless you. may the Gods smile on you.
Thank you for your write up and the tips on doing this without dropping the subframe. I have a '98 V70 X/C and a P0740 code for the lock-up solenoid. I checked the resistances of all my solenoids this past weekend hoping I had a wire issue instead of a bad solenoid. No such luck. The lock-up solenoid measured 160 ohms no matter which way I manipulated the wiring. I also have one of the other shift solenoids (S2 if I remember right) that was reading just over 15 ohms while the other was about 12 ohms. Since I'm going to have to "go in" anyway, I figure I will replace S1, S2, and the lock-up solenoids. Being I have a '98, does anyone know if the numbers listed at the beginning write up apply to my car? Also, thanks for the tips/link to Trans Parts; awesome prices. Thanks in advance for any info!
polskamafia mjl
Try emailing them and see what they say. They were pretty helpful when I talked to them.
- Has thanked: 1613 times
- Been thanked: 4075 times
Bumping this great thread to discuss gasket solutions
- ZionXIX
- Has thanked: 66 times
- Been thanked: 195 times
Wow this is a Great thread. The gasket problem makes me wonder if I could just put that material through a laser cutter.
- 5718 Views
Last post by SuperHerman
- 643 Views
Last post by crazycat
- 1613 Views
Last post by Geno9707
- 1350 Views
- 1424 Views
Last post by Tsquared
