Yes COMBI is instrument cluster in "850 OBDII" (the android app).
I have no issues on the speedometer.
Some time ago the ABS indicator used to light up when I was accelerating "strongly", but it doesn't do it anymore.
Maybe that could add to the ABS module hypothesis ?
Hesitation on WOT (V70 2.0 T5 AWD 1997) Topic is solved
- Fiodor
- Year and Model: 1997 V70 2.0 T5 AWD
- Has thanked: 13 times
- Been thanked: 9 times
Changing fuel to Unleaded95 didn't change anything.
I've driven the car on the highway and my issues happen in every gear.
In 4th gear it feels as if I'm running over things, kinda unnerving.
1997 V70 T5 2.0 AWD with welded angle gear at 240k km
1990 740 Break (dead)
Did you try Volvo plugs?
Another easy thing to do is jump the fuel pump relay with wire to see if it is hot failing.
- Fiodor
Not yet but do you think that could explain my DTCs ?
Does the faulty ABS module theory sound like a good one to you ?
- Fiodor
Ok so I went to my dealership to buy the plugs and the mechanic told me to replace the fuel filter before anything else, guess what I'm doing tomorrow
I'll update my post once I've done it !
- misha
- Has thanked: 155 times
- Been thanked: 432 times
CombiFiodor wrote: 26 Nov 2018, 14:11 DTCs checked !
COMBI :
124 Engine RPM Signal faulty
221 Vehicle speed signal Missing [bad ABS module solders?]
222 Vehicle speed signal too high
ECC :
414 Driver's (or passenger's) side interior temperature sensor inlet fan seized (or open/short circuit or faulty signal)
The 3 COMBI DTCs remain after erasal.
What could be causing these ?
That should be tdc sensor for the rpm signal and speed sensor from transmission.
Don't know why they are stored in instrument cluster....they should be stored in ecu.
Ecc is not relevant for your symptoms.
New fuel filter and spark plugs will not re-solve the codes you have.
Rpm sensor and vehicle speed sensor have nothing to do with abs module....their playground is at transmission and flywheel.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- misha
New fuel filter and good spark plugs will not hurt anything..but they will not clear the codes you have...and i doubt that they are real.
Also....android app code reader is not to be trusted almost never...ecu codes stored in instrument cluster....do the math yourself.
ONLY Volvo special tool(at least Vol-Fcr) can have access in all modules in the car...generic ones can read just ecu.
Is your V70 T5 M4.3 or M4.4?
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Are these cars specified for E85 fuel?
- misha
Not without some additives added and software upgrade...according to their site.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- 573 Views
Last post by hausmeister
- 28 Replies
- 3623 Views
Last post by misha
- 1221 Views
Last post by Homebrand
- 5166 Views
Last post by pkc303
- 1317 Views
Last post by Levinicus
