just come to thinking of could it have something to with the hydraulicpump ?
because sometime I think the noise comes from different wheels
have driven with different people and some front and others say back and some says left and others right
brake noise
- MoVolvos
- Has thanked: 312 times
- Been thanked: 525 times
How about swapping the rotors left to right and right to left if they do not have directional slots or directional drilled vents? Be sure to note any difference in the noise or perhaps it'll go away.
- MoVolvos
- MoVolvos
Part 17 new from last year or now while fixing noise?
So looking at the original post again till now:
1) Changed to 16" last year.
2) 16" started to make noise 6 weeks ago.
3) Changed a bunch of parts and adjusts
Assuming 1 ~ 3 is correct did the noise changed at all anytime during all the change in parts and adjustments?
jantt
- Year and Model: C70 2000
- Been thanked: 2 times
No the pins from this that goes into the control unit
https://www.ebay.com/itm/NEW-Genuine-AC ... SwHN9cetzO
- MoVolvos
Since the noise began with the old set of brakes then a part from last year which was not changed out is causing the problem. Did you hit any large pot holes or run up a curb? Alignment been checked?
Not familiar with that part but why do you suspect that unit?
jantt
Yes started with old parts and then started to change
Has changed rotors, pads, caliperes and hoses
Has hit no holes
I suspect that part because sometime I think the noise comes from left and right.
Sometimes front and somtimes back
The pins move in and out into pistons in the control unit
If the pins sometime hang then it could cause it?
Has hit no holes
- 2283 Views
Last post by MoVolvos
- 2448 Views
Last post by Ou2mame
- 1171 Views
- 727 Views
Last post by jtp
- 2738 Views
Last post by RickHaleParker
