Also, adding to the topping. I got suggestion to swap all electronics (pnp switch, sensors, etc) from my 99 to that 2000 trans and it should work. 2000 car was turbo 2.4 but I do not have the vin from it.
Both 1999 and 2000 4 speed trans with Turbo-charged engine models have gear ratio 2.56:1 as far as google search.
99 V70R - lost reverse
- FLXC90
- Year and Model: 98 V70 T5
- Has thanked: 16 times
- Been thanked: 45 times
http://volvospeed.com/vs_forum/topic/18 ... omponents/ a lot to digest, but empirical. lots of part number changes spelled out. along with what matches.
Best bet, find a 99 XC or 99 FWD turbo. If you pick FWD, you can sell your angle gear and prop shaft. Or you could re-convert later.
Third pedal option? V50 AWD donor!!!
Current Volvos:
- FLXC90
https://row52.com/Vehicle/Index/YV1LT56D7X2585552 Here's a 99 AWD in a yard. Looks like they rear-ended someone. Enough damage for insurance to total it, but light enough that I doubt the trans would be bad. You may try to get someone to pull it for you and ship . It has its risks, but possibly its rewards as well.
Current Volvos:
- kklepack
- Year and Model: 2016 XC60
- Has thanked: 12 times
- Been thanked: 5 times
Thank you for the link looks like it is in Canada so shipping will most likely expensive. I will keep looking for one closer to Chicago.FLXC90 wrote: 28 Sep 2020, 18:37 https://row52.com/Vehicle/Index/YV1LT56D7X2585552 Here's a 99 AWD in a yard. Looks like they rear-ended someone. Enough damage for insurance to total it, but light enough that I doubt the trans would be bad. You may try to get someone to pull it for you and ship . It has its risks, but possibly its rewards as well.
On top of it I called dealer's, Erie Vo-Vo, Vandsautodismantlers was not able to get an answer on what is the difference between
99 R vs 99 AWD transmission. Search is still on.
- Has thanked: 1611 times
- Been thanked: 4075 times
If you look the specs up in the owners manual (online) if there are gear differences those would be listed.
The volvo web store also list options , too
- kklepack
Online Owners Manual for 99V70R and 2000 S70AWD have the same Final drive Turbo-charged models: 2.56:1abscate wrote: 29 Sep 2020, 09:09 If you look the specs up in the owners manual (online) if there are gear differences those would be listed.
Reduction ratios
1st gear 3.61:1
2nd gear 2.06:1
3rd gear 1.37:1
4th gear 0.98:1
Reverse 3.95:1
So, I think these trans are very very similar. Can some one please prove me wrong?
Here’s what I have for you
Same part number for both the T2,and T3 engine variation.
- FLXC90
The basic transaxles are the same for the AWD(GLT), XC, and AWD (R), it's the suspensions, and in the case of the R, the motor that differ.
Current Volvos:
There is a 1998 XC for sale in Aurora nearby in Classifieds
- kklepack
You are giving me a hope.FLXC90 wrote: 29 Sep 2020, 20:54 The basic transaxles are the same for the AWD(GLT), XC, and AWD (R), it's the suspensions, and in the case of the R, the motor that differ.
- 2076 Views
Last post by PeteB
- 946 Views
Last post by hharrell4th
- 1568 Views
Last post by bmdubya1198
- 3507 Views
Last post by KurtL
- 224 Views
