When the camshafts are in that position the dots line up. The alignment tool is to get the camshafts in the correct position. Which is the datum.zakmuh wrote: 11 Dec 2021, 11:05 Removed everything again and checked. Single dot on the intake shaft (right) is in the middle of double dots on the exhaust shaft, as shown in the pic.
Please Help with this Popping Noise
- RickHaleParker
- Been thanked: 977 times
Active
Past
Past
zakmuh
- Year and Model: 2003 XC90 D5
- Has thanked: 6 times
All look okay...so before I install all back on, should I double check anything else Rick?
When I undid the common rail and high pressure pump line this time, diesel didn't drip. I'll have to prime it?
zakmuh
Hi Rick,
I called RAC, the breakdown guys. They used this easy start thingy sprayed through the intake and car started straight away and ran fine. The the guy suspects that I might have got the timing in the high pressure pump wrong. Diesel comes to the pressure pump through the line and then from pressure pump it just squirts, no pressure at all.
- RickHaleParker
I think you got the timing off too, because you started with the wrong datum. Use a camshaft alignment tool. Timing is critical on a diesel because, compression is what ignites the fuel. Go back through it and this time do it by the book.
Active
Past
Past
zakmuh
When removing the pump I didn't pay attention to pump timing. So when I took it off this time, non of the slot (1 and 2 in the pic) was in the middle of the two line marking on the pump.
I tried these steps but wouldn't start:
a. No 1 positioned between two line, then turned crank pulley till camshaft grove aligned with No 1
b. No 2 positioned between two line, then camshaft grove aligned with No 2
Whats the correct way to do the timing?
Thanks in advance
Thanks in advance
zakmuh
Thanks for your reply mate. Sorry I didn't see your comment while writing the above post. I think I'll be better of giving the car to a garage to sort this out. I'll keep you postedRickHaleParker wrote: 12 Dec 2021, 11:17 I think you got the timing off too, because you started with the wrong datum. Use a camshaft alignment tool. Timing is critical on a diesel because, compression is what ignites the fuel. Go back through it and this time do it by the book.
Cheers
- RickHaleParker
Do you have VIDA? The instructions are in VIDA. If not install it.
Active
Past
Past
zakmuh
Thanks, yeah I have VIDA but struggling to find the instruction for camshaft alignment. Would you know the section number?RickHaleParker wrote: 12 Dec 2021, 11:38 Do you have VIDA? The instructions are in VIDA. If not install it.
- RickHaleParker
Information / Repair / Overhaul. Then find Cylinder head install in the left menu. May sure you have the crankshaft aligned before doing the camshafts.zakmuh wrote: 12 Dec 2021, 13:52
Active
Past
Past
zakmuh
Nice one RickRickHaleParker wrote: 12 Dec 2021, 15:03Information / Repair / Overhaul. Then find Cylinder head install in the left menu.zakmuh wrote: 12 Dec 2021, 13:52
Please correct me if I'm wrong with these steps:
1. Get timing marks aligned to markings on timing belt sprocket and camshaft sprocket dots
2. Remove timing belt (drive belt still in place)
3. Lock the camshaft through the hole behind vacuum pump using alignment tool
4. Lock the crankshaft behind the starter motor using other alignment tool
5. Rotate crank pulley anti clockwise until it hits the alignment tool and stops
6. Refit timing belt, vacuum pump and starter motor
Thank you
- 11 Replies
- 3525 Views
Last post by hunterhuni
- 1431 Views
Last post by oragex
- 1569 Views
Last post by chris11211
- 555 Views
Last post by GlennG2759
- 2678 Views
Last post by SuperHerman
