96 850 Turbo Wagon: what other tires can I mount on my 16" alloy rims?
insession
- Year and Model: 1996 850
- Been thanked: 2 times
Thanks misha. I confess I wasn't aware that the options/choices here were that black/white. Looking at what I got, my wires were NKG's, cap bosch, rotor Standard Motor Products, plugs champion. I will pull them and check the gap. Do you know off-hand what it needs to be for the Turbo?
- misha
- Has thanked: 155 times
- Been thanked: 432 times
0.026"(0.6)or 0.028"(0.7mm).
It is better to re-install your old original rotor instead of that aftermarket junk...which btw....i never heard about.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- Been thanked: 4068 times
It’s MVS lore that Bougicord spark plug wires are the only ones that have been consistently problem free. The are run in close proximity on these cars so any quality issues in the wires will make them crossfire
- Has thanked: 2202 times
I won't talk for abscate, but there is an area where the wires pass under the top cover just by the top torque mount. This area and the cover can be tight to fit the wires in. I found in one car I had that the spark plug wires were crushed and shorting in that area.
The Bougicord branded parts are recommended as experience of man members is that they are the OE brand and seem to be very reliable. There are other brands out there like NGK and others but we have had mixed reports on the reliability of these brands. I have a friend whose car I worked on recently and saw it had NGK wires on it. Seemed to be running ok.
- FireFox31
- Has thanked: 159 times
- Been thanked: 303 times
I've run 205/55/16 tires on my 2000 V70 for a decade. The fronts rub on the plastic at full lock. I've conditioned myself to turn to the lock, then back off a tad. Part of the problem could be my worn out, original suspension.
FireFox31
- 538 Views
Last post by 5rivers
- 1620 Views
Last post by JRL
- 1889 Views
Last post by Volvo S80
- 1320 Views
Last post by V50M66
- 5817 Views
Last post by MadeInJapan
