Vida CEM swapping
Dudde
Year and Model: 2005 V70 and more
Has thanked: 16 times
Been thanked: 17 times
Post by Dudde »
oscilloscope wrote: 05 Nov 2022, 15:16
rkam wrote: 05 Nov 2022, 15:05 Here is an attempt on decrypting the eeprom.
out.rar
45 61 80
26 08 16 54 70 79
I can already decrypt the eeprom. I need a synchronisation.
I need ABS id
oscilloscope
Has thanked: 27 times
Been thanked: 11 times
Post by oscilloscope »
Dudde wrote: 07 Nov 2022, 14:54
out.rar
45 61 80
26 08 16 54 70 79
I need ABS id
As far as i know Abs id is not required for cem L or H
yagger
Year and Model: V60 2016
Has thanked: 6 times
Been thanked: 39 times
Post by yagger »
oscilloscope wrote: 04 Nov 2022, 00:34
yagger wrote: 03 Nov 2022, 20:05 What way do you mean? There is commercial way for example... )
Yes I have herd of them , from what I remember there very exspensive. , although at this current time It wouldn't load on my phone. So I couldn't confirm if its the same price.
If you tell by phone about "this" case and forum topic, price for this option is $150 for you. If you have a DiCE it is possible to do everything via Internet. If you do not have a DiCE also need to pay for shipping.
oscilloscope
yagger wrote: 08 Nov 2022, 11:50
At the time I couldn't see the fee on there site as it wouldnt load correctly. , and that price out ways the cost of the job., by way off. I have considered purchasing DiCE
RickHaleParker
Been thanked: 979 times
Post by RickHaleParker »
yagger wrote: 08 Nov 2022, 11:50 If you have a DiCE it is possible to do everything via Internet. If you do not have a DiCE also need to pay for shipping.
If VIDA is not installed on the remote machine, is DiCE the only J2534 interface you can work with over the internet?
Active
Past
DJGlock
Year and Model: 2007 XC70
Has thanked: 5 times
Post by DJGlock »
T5Luke wrote: 04 Sep 2022, 02:39 Sorry was 50 downloads only, here are both again...
Also Windows 10 doesn't notice me about anything, maybe it is location based on 3 computers i get nothing. Maybe defender in US sees something problematic in this code...
Dear T5Luke
I tried to use UDSTool Crack to get PIN for my XC70, but got the following issue.
Car: XC70 2007, YV1SZ595771286825
Dice: Chinese clone, but works good (as per my experience).
Repro steps:
The car stayed for a day, I just opened it, connected DICE and run your tool. Did not touch ignition lock at all (so it was in position 0).
It tried to start the process, but failed (log below).
Repeated several times - no luck. Had a small conversation with vtl, he advised to ask for help here.
Does the response from CEM tells you anything useful? Vtl told me that it looks like one of modules did not enter sleeping mode and hence the response was bad. Any ideas how to fix it? May be you have any other build with extended logging?
yagger
Post by yagger »
RickHaleParker wrote: 09 Nov 2022, 02:16
VIDA not need. DiCE is required.
NuovoRecord
Year and Model: 2004 V70
Post by NuovoRecord »
Are there any tricks to soldering to these ECU pins? I just had a hell of a day trying to get wires connected. The pads seem to lift at the slightest movement.
vtl
Year and Model: 2005 XC70
Has thanked: 130 times
Been thanked: 686 times
Post by vtl »
NuovoRecord wrote: 20 Nov 2022, 19:26 Are there any tricks to soldering to these ECU pins? I just had a hell of a day trying to get wires connected. The pads seem to lift at the slightest movement.
30AWG copper wire w/ silicone insulation, regulated soldering iron/station.
NuovoRecord
I managed to brick my CEM. Be careful.
