Going to start with the ABS module
Has thanked: 2207 times
Been thanked: 1852 times
The TPS could be causing an issue, but you will be surprised what the ABS unit does when you are not getting a clean speed signal to the ECU. I guess we will find out in due course.
454cid
Year and Model: 1996 850
Has thanked: 151 times
Been thanked: 139 times
Post by 454cid »
scot850 wrote: 03 Jun 2022, 14:04 The TPS could be causing an issue, but you will be surprised what the ABS unit does when you are not getting a clean speed signal to the ECU. I guess we will find out in due course.
Before work Friday, I was briefly able to use the 850obd2 app to graph the voltage from the TPS and I captured an instance of the voltage suddenly spiking. There was no voltage stated, but I'm guessing it's randomly shorting. I've got a new TPS ordered and should be here Saturday sometime, and in the meantime, I'll do some more testing on the existing TPS, and try to clean it.... maybe clean the throttle body too.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
1999 Chevrolet K3500
1969 Buick LeSabre Custom 400
454cid
Post by 454cid »
abscate wrote: 03 Jun 2022, 04:03 Just don’t start with something too crazy….. :lol:
viewtopic.php?t=95351&start=120
Oof, that's rusty! I didn't read the whole thread, but did skim it..... what finally happened with that car?
This V70 is not as clean underneath as my 850, but wasn't horrible. If I can get it cheap enough, I was actually thinking "winter beater", so I can save my 850 from the salt..... and it would just be cool to have a wagon.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
454cid
Post by 454cid »
New Bougicord plug wires.... are tool tall??? The tops would not sit down in the plug wells, so I compared to the originals, and the new ones are about 3/8" taller! I put the old ones back on, but measuring ohms, they're not consistent.
I replaced the TPS, and while running for a few minutes in the driveway it seemed fine. I moved on to the ABS module finally, and it came out fine. HOWEVER, the insulation on the power wires absolutely disintegrated! One second they looked fine, the next second pieces! I have never seen wire insulation do that before. I guess I need to research THAT now....sigh.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
misha
Has thanked: 155 times
Been thanked: 432 times
Post by misha »
Bougicord blue ones are for 10v cars.
Grey ones(like originals) are for 20v cars.
Part # are different...you should have checked original part# before ordering.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
454cid
Post by 454cid »
misha wrote: 05 Jun 2022, 14:27 Bougicord blue ones are for 10v cars.
I'll have to go look to see what color they are. I ordered them from FCP.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
454cid
Post by 454cid »
I'm guessing you mean the part that reaches the plug in the plug well, not the actual wire..... wire is black. I think maybe the wires I got are mis-boxed, The FCP picture shows gray, and lists the part number I have.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
misha
Post by misha »
454cid wrote: 05 Jun 2022, 17:14 ...I'm guessing you mean the part that reaches the plug in the plug well, not the actual wire.....
Yes.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
454cid
Post by 454cid »
misha wrote: 06 Jun 2022, 16:28
Yes.
It looks like I ordered 6468, and got 6469 in the box.... so a mislabeled box.
I've already contacted FCP and they want my VIN number :roll:
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
Has thanked: 1610 times
Been thanked: 4071 times
Might be a chassis break on these? Did you try volvopartswebstore?
