Haldex Oil Pump Replacement Topic is solved
vtl
Year and Model: 2005 XC70
Has thanked: 130 times
Been thanked: 686 times
Post by vtl »
XC70Rider wrote: 27 Jan 2024, 12:01 After siphoning the dirty warm fluid let it drip down for at least 30min then do another siphon. Should get at least 300ml siphoned out. I edited the previous post to add that tip.
I greased all the mating surfaces, the subframes moved as far apart as possible, and I invested into a dedicated impact socket that I cut flush to have a good grip on that shallow nut. It takes me very little time to remove the driveshaft and the flange to have the best access to everything :)
Antoine240bk
Year and Model: XC70 2.5T-2006 - 4C
Has thanked: 12 times
Been thanked: 30 times
Post by Antoine240bk »
Here is the counter hold tool and the puller. The 5 years old flange should come off easy.
Volvo XC70 2.5 T AWD P2 B5254T2 - 12/2005 Four-C Previous : Volvo V70 P1 2.4l 20s 170ch B5244S 03/2000 - Volvo 245 GL Break 1979 B21 -LPG - Volvo 240 GL Break 04/1992 B230F (Daily for 14 years)
XC70Rider
Year and Model: 2007 XC70
Has thanked: 36 times
Been thanked: 42 times
Post by XC70Rider »
Antoine240bk wrote: 28 Jan 2024, 10:25 Here is the counter hold tool and the puller. The 5 years old flange should come off easy.
With replaced CV joints and Haldex Flange I had everything removed quick and easily. I put grease on the CV joints end caps and casing.
With a high torque air impact wrench the flange nut is no task to remove. New oil pumps come with a new flange nut so now I have two used spare flange nuts.
