How do you read timing in VIDA?
Has thanked: 1610 times
Been thanked: 4071 times
dono wrote: 09 Apr 2025, 11:39
erikv11 wrote: 29 Mar 2024, 16:22 VVT is new Volvo branded, bought from FCP.
Was super careful with the VVT rotation triple checked it etc., but I will check it again when I take it apart this weekend.
Did not lock the crank but had the harmonic balancer off, very sure it stayed on the mark.
Back of the cams did not break. Yet.
Those CAM hubs are tightened to 120Nm so when you loosen (or tighten) with that level of force Im not certain how you can do that without moving the cam shaft out of timing. Love to know if/how you ever found vida dice procedure for timing and cam adjustment...
You lock the cams in the rear of the motor with a ….drum roll…..cam lock tool. Tighten those long 10mm bolts finger tight, don’t use a tool
https://www.fcpeuro.com/products/volvo- ... gIgL_D_BwE
dono
Year and Model: 04 V70&XC70 2.5T AWD
Has thanked: 43 times
Been thanked: 6 times
Post by dono »
abscate wrote: 11 Apr 2025, 04:35
(my bad I was unclear - I was trying to be polite and ask how HE loosened the bolts without a camlock tool - I dont think its possible without the tool and I would never try without the cams firmly locked)
2004 V70 AWD Wagon 2.5L L5 DOHC 20V TURBO 268k mi :D
2004 XC70 AWD Wagon 2.5L L5 DOHC 20V TURBO 155k mi :D
1999 Mercedes e320 4Matic 238k mi :D
2008 Toyota Avalon XL 165k mi (meh)
dono
Post by dono »
dikidera wrote: 10 Apr 2025, 11:23 I did not tighten mine to 120nm, was too scared for something to snap.
That is the spec. Those are Big bolts. I hope you came close to 120nm and/or used locktite cause you definitely do not want those camshaft adjusting hubs coming loose!
Has thanked: 311 times
Been thanked: 817 times
Post by erikv11 »
I used the cam tools to lock the cams.
dono wrote: 09 Apr 2025, 11:39 Love to know if/how you ever found vida dice procedure for timing and cam adjustment...
Cam timing was all done mechanically. The crux of it is that they must be fully clockwise from the front, when the cams are locked at the back. I used VIDA later on to check the timing, but not to adjust it.
dikidera
Year and Model: S60 2005
Has thanked: 68 times
Been thanked: 187 times
Post by dikidera »
dono wrote: 11 Apr 2025, 13:53
I did not use loctite. I had set my torque wrench to 120nm, I tightened it a lot, but it never clicked at the time, and I was too scared to continue.
I have been driving it for 2 years now so...
vtl
Year and Model: 2005 XC70
Has thanked: 130 times
Been thanked: 686 times
Post by vtl »
dikidera wrote: 12 Apr 2025, 01:09 I did not use loctite. I had set my torque wrench to 120nm, I tightened it a lot, but it never clicked at the time, and I was too scared to continue.
Unless you are like 50 kilos, 120 nm is not that much :)
jonesg
Year and Model: 2004 V70
Has thanked: 73 times
Been thanked: 534 times
Post by jonesg »
Saved from the shop. !
those O2 sensors should give indication of a problem, maybe you'd need to drive with vida hooked up under load to see it.
