Sheared water pump bolt
callahanoffroad
Year and Model: 1995 850
Has thanked: 16 times
Been thanked: 53 times
Post by callahanoffroad »
Knowprblm 97 wrote: 14 Apr 2021, 18:30 Volvo 850 1994 n/a. Snapped water pump bolt flush to the head. Drilling bolt left oval hole as drill bit wandered during drilling. I'm left with oval shaped hole where the bolt was. What is the best way to repair? Steel putty or weld
I did in fact leave mine out, ran over 100,000 miles with no leaks. It's not the correct way to do it, but it did work just fine missing one bolt.
Author, Chef, and Shade Tree Mechanic
1995 Volvo 850, Non-Turbo, VVIS, LH FI, Green, 215,000 miles. B5254FS engine. Herman. viewtopic.php?f=1&t=84393
1996 Volvo 850, died at 280,000
Founder of: CookingForChemo.Org
Read my Silly Comic Book at: therealpizzabros.com/
Has thanked: 1610 times
Been thanked: 4069 times
I’m proud of you for publically posting you have a screw loose.
callahanoffroad
abscate wrote: 15 Apr 2021, 05:17 I’m proud of you for publically posting you have a screw loose.
:lol: it's a fact
800artfreed
Year and Model: 98 S70T5; 99 S70GLt
Been thanked: 26 times
Post by 800artfreed »
I know that this position of the bolt on our cars makes the following techniques not that applicable, but they are very informative. I like both the door hinge screw guide and the homemade bolt guide. Check it out.
VolvoVoyeur
1998 S70-T5 200K+
1998 V70-T5 200k+
1999 S70-GLT 80k+
Eddystone
Year and Model: 1967 Ford GT40 Mk IV
Has thanked: 63 times
Been thanked: 81 times
Post by Eddystone »
abscate wrote: 15 Apr 2021, 02:17 I think I would JB weld it, the drill and tap the JB weld for the M6 bolt. Some recently did this successfully here
JB Weld is one of the greatest inventions of the modern era or at least of the 20th century. There's no situation that a little JB Weld can't improve, if not completely remedy.
All U.S. market models.
All running and on the road.
RickHaleParker
Been thanked: 980 times
Post by RickHaleParker »
800artfreed wrote: 15 Apr 2021, 13:48 the homemade bolt guide.
The Socket head guides are a neat solution if you have a drill press or a lathe to to make them.
Eye balling to drill the Socket Head straight will not cut it.
Active
Past
800artfreed
Yes for most of us we would use a drill press. One of this guy's videos shows how to use a press to make such a socket bolt drill guide. Too bad I have neither press nor lathe.
VolvoVoyeur
1998 S70-T5 200K+
1998 V70-T5 200k+
1999 S70-GLT 80k+
kallekula
Year and Model: S70 2000
Has thanked: 58 times
Been thanked: 75 times
Post by kallekula »
Just the sight of a screw extractor makes my skin creep. Oh the memories...
BMW 540i 2002
S70 Base 2000
Knowprblm 97
Year and Model: 850 GLT
Post by Knowprblm 97 »
Thank you for replies to my oval drilled out hole. I wound up tapping the hole out and got a 8 mm bolt to snug up the water pump. 3 weeks with no leaks!!
I just wanted to say our bolt did not snap on the way out, but on the way in. We purchased the asin water pump online but did not compare it to the original volvo pump. Our mistake was using the old bolts which were 1/4" too long for this pump. The new water pump was thinner allowing the old bolt to bottom out in the block before coming to rest on the water pump. Moral of story is to always use new bolts
Knowprblm 97
