95 850 Manual Wagon won't engage any gears
Year and Model: 2001 V70
Has thanked: 987 times
Been thanked: 1075 times
Post by volvolugnut »
Can you examine the C clip GROOVE to see if it is damaged? Inspection mirror or Boroscope may work for this. The groove may now have a bevel on the outside edge that will not secure the C clip. This may have occurred when the end of the first axle was damaged.
Has thanked: 2200 times
Been thanked: 1852 times
Can you check the overall lengths of the axles? I'm assuming the old one on the right is the original? If so, in the picture it looks longer than the others.
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 316 times
Been thanked: 531 times
Post by bmdubya1198 »
Yeah, the original axle definitely looks longer in the picture.
firestarterpro
Year and Model: 850 NA - 1995
Has thanked: 2 times
Post by firestarterpro »
With the boot torn on the old one, it does look longer.
However, when you line them up straight and compress them together from both ends, they're the same size.
Before I put in the 3rd one, I took pictures of the inside.
I felt the groove and the edges the circlip goes into felt flush
I should order an Volvo axle from FCP overnight and return all of these....
but I'll test drive it around the block a few more times i guess
._____________,
||------|---||---||__\ \___
\=-(@)-===-(@)-=*B
The proudest owner of a Naturally Aspired 2.4L Volvo 850 Wagon of 1995!!! :o :o :o
94 850 NA Wagon was hit and totalled at 350k :oops:
96 850 NA Sedan sold at 180k :arrow:
95 850 Turbo Wagon sold at 260k for parts :!:
95 850 NA Wagon sold at 220K :arrow:
bmdubya1198
It doesn't look damaged, but you'd have to inspect it with a mirror or borescope to be sure. That's a good sign, though.
A new Volvo axle will be your best bet, even though they're expensive. Aftermarket axles for these cars are just a pain!
Thanks for the photos. It is hard to see clearly, but I don't see damage to the C clip groove.
Another crude inspection idea: get some modeling clay and press a ball into the groove area. Carefully remove the clay and inspect the groove impression. This may reveal something you can't see.
firestarterpro
After some testing, i feel confident the last axle from API is adequate
It seems even a couple millimeters can cause failure
I'll either buy Volvo next time, or painstakingly measure both side by side
._____________,
\=-(@)-===-(@)-=*B
