Only Drained 90oz Of Coolant Topic is solved
jonesg
Year and Model: 2004 V70
Has thanked: 73 times
Been thanked: 534 times
Post by jonesg »
does the temp gauge in the dash never move ?
pretty sure it takes longer than a minute to start moving.
if it never moves I'd check the fuse first, then the harness.
Oka
Year and Model: XC70, 2001
Has thanked: 9 times
Been thanked: 4 times
Post by Oka »
No, the gauge never moves.
Starting and letting the car run for a few seconds and turning off starts the fan to continue to run and stop latter.
All the lights in the instrument panel works, including the Check Engine light.
The temp gauge does not have it's own fuse to check, or does it?
jonesg
Post by jonesg »
its all pointing back to the temp sensor you replaced, did you check voltage at the plug?
it should drop as engine warms up. see if you can backprobe the plug.
Oka
Post by Oka »
jonesg wrote: 27 Sep 2020, 20:26 its all pointing back to the temp sensor you replaced, did you check voltage at the plug?
Yesterday, (9/26/20) I posted the voltage from the new temp sensor. Was that what you mean? I did not start our run the engine before taking the voltage.
What is "backprobe" and how is that done?
Oka
Post by Oka »
jonesg wrote: 23 Sep 2020, 22:55 maybe the thermostat isn't opening.
If the thermostat is not opening, shouldn't that (the large air pocket) in the upper hose cause the car to overheat? The whole upper hose seem to be empty.
Seems I have two issues, with new thermostat and CTS:
1. No coolant in the upper hose.
2. Temperature gauge smack down, does not move.
Has thanked: 1610 times
Been thanked: 4071 times
Did you use an OEM thermostat and sensor?
Aftermarkets have a high Failure rate Out of box (OBQ in QC-speak)
Oka
Post by Oka »
abscate wrote: 28 Sep 2020, 04:40 Did you use an OEM thermostat and sensor?
Both were AutoZone brands.
Please what is "(OBQ in QC-speak)"?
Out of box quality, or , in the vernacular, sh****ty parts
Oka
Post by Oka »
abscate wrote: 28 Sep 2020, 07:20 Out of box quality, or , in the vernacular, sh****ty parts
Thanks. I learn everyday.
jonesg
Post by jonesg »
Oka wrote: 27 Sep 2020, 22:42
You need to read the volts as the engine warms up to see the sensor changing resistance.
Sounds like you just read the feed voltage.
they sell probes or you can make them from paper clips and insulation tape to prevent them touching.
