hi
i just changed bubls in my volvo 850 instrument cluster lights and gear and also ashtray .....
here are some examples and pictures of bulbs
glove box:
http://www.bulbdirect.com/products/prod ... &cat_id=44
the small indicator light (check engine...lmabda...low fuel ) these bulbs also do in bmw's (about 20 of them) wagner also makes them...
http://www.donsbulbs.com/cgi-bin/r/b.pl/509~lucas.html
the 4 big lights in the cluster
http://cgi.ebay.ca/194-BLUE-LED-LIGHT-B ... 240%3A1318
cigarette lighter and gear selector
http://www.fcpgroton.com/product-exec/p ... gory_id/22
here is sylvanias parts numbers
Parking light
1156
1156LL Long Life Upgrade: Up to twice the life of the standard lamp
Front turn signal
1156
Rear turn signal
1156
Tail light
67/97
Stop light
1156
High mount stop light
1156
2825
2825LL Long Life Upgrade: Up to twice the life of the standard lamp
License plate
2825
Back up light
1156
Ash tray
2721
Glove box
17053
Map light
64111
Dome light
64111
Step/Courtesy light
2821
2825
Trunk/Cargo area
6411
Instrument-general
2721
2821
Check engine indicator
2721
Hi-beam indicator
2721
Seat belt indicator
2721
Brake warning
2721
Automatic transmission indicator
2721
Directional signal indicator
2721
hope it helps...these bulbs fitted in my car
Bulbs, bulbs, bulbs...interior bulbs.
Interior bulbs designation, sizes, etc.
volvomileage
- Year and Model:
volvo 850 95 sedan non/turbo 185 k
- Has thanked: 17 times
- Been thanked: 35 times
Wow! Thanks, volvomileage
I have a '98 S70 T5:
Does anyone know anything about the green light on the back of the console that shines onto the floor of the back seat? What type of bulb is it? And will I have to take out the whole console to fix it. There's nothing in my owner's manual about this bulb, and I haven't been able to find any info on it.
So whatever you can give me would be great.
Thanks!
Thanks!
VCA
- Year and Model: 2008 S80 T6 AWD
- Been thanked: 5 times
You don't have to pull the console to change that one. It's part of the cigarette lighter assembly. If you get your hand underneath the panel (so your hand is between panel and carpet), and pull gently out and slightly up, the panel will pop out. The bulb is Volvo 942327, more affectionally known as a 2721 bulb.TylerS70 wrote:I have a '98 S70 T5:
Thanks!
2008 S80 T6 AWD
1999 S70 GLT
1999 S70 GLT
zhenya
- Year and Model: 97 855 T5,98 V70 AWD
The light for the passenger seat heater is out. Can anyone tell me what I need to do to replace this one? Anyone have a part number for a replacement? (I didn't see this in the list above).
Oops, this is in a 97 855.
double_platinum
- Year and Model:
Same bulb/procedure as for all of the dash switches (fog lights, sunroof, locks etc etc), besides for the INFO selectorThe light for the passenger seat heater is out. Can anyone tell me what I need to do to replace this one? Anyone have a part number for a replacement? (I didn't see this in the list above).
96 855 Turbo Platinum edition 137K
96 854 Turbo Platinum edition 211K
94 965 271K
94 965 271K
Having been quoted £4.75 +VAT for a bulb for my heated seat switch will these bulbs do the same job.
- Year and Model: Many Volvos
- Been thanked: 76 times
Unfortunately it is a completely different base than the 12velectronics bulbs. I'm not sure what you have that is like Radio Shack but to repair those lamps I buy a 2 pack of Radio Shack part number 272-1092 lamps for $1.79 US and then cut the old lamp out of the socket with a Dremel tool cutoff wheel, just enough to nip through the wires from the lamp to the socket terminals. I then solder the Radio Shack replacements back into the OEM socket.carp-guru wrote:Having been quoted £4.75 +VAT for a bulb for my heated seat switch will these bulbs do the same job.
http://www.radioshack.com/product/index ... Id=2103780
Any decent wholesale electronics parts supplier should be able to come up with a similar pigtailed lamp that will fit.
pfk1006
Great site, tons of information.Glenspread wrote:Three of my instrument lights were dead - I guess when lights start to go, the others start to follow. I found some great instructions here:
http://www.seawinds.ws/volvo/instrument_cluster.htm
I replaced all 4 of the main bulbs and the one clock back light bulb. The main bulbs are referred to as W3W "wedge" bulbs. They snap in and out to their holder. Pep Boys, AutoZone and others carry them. Look for Sylvania 2821, 12v 3w. $2.99/pkg of 2.
I bought the clock bulb from Volvo as it was only $2.98 (!!).
TIP: there are a LOT of lights in the instrument cluster. Carefully write down which areas are dead before you take everything apart. You want to avoid having to repeat the removal because you missed one (I did).
The link is broken, can I get any help on how to remove the dash / instrument cluster to replace the burnt out lights? Thanks
Certainly-
I hope this helps: http://volvospeed.com/Dashremove.php
- 5107 Views
Last post by AVOIT17
- 1240 Views
Last post by Baptiste1106
- 1213 Views
Last post by sergio
- 855 Views
Last post by rspi
- 384 Views
Last post by T64me
