Give me a ring next time if you got stuck again.
'98 Alternator/Power Steering pump refit -- A Cry for Help Topic is solved
confused_al
- Year and Model: 1996 TLA wagon
You are welcome! Nice to meet a fellow Volvo nut as well
96 850 Platinum Wagon
98 MB ML320
06 V70
95 850 GLT(RIP)
98 MB ML320
06 V70
95 850 GLT(RIP)
- E Showell
- Year and Model: ‘07 S80 3.2
- Has thanked: 37 times
- Been thanked: 112 times
Happy to report everything is back together as it should be. The car performed well on a longish test drive, but I have yet to attempt drawing a vacuum and recharging the a/c system. The priority was making the car drivable which it is.
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
'95 855 auto (sold)
Checked this one off as solved using the checkbox button next to thread title, on far right
- E Showell
Ok, so just when I thought I was in the home stretch, my 6 gal. pancake compressor broke before I could get the system vacuumed and recharged. Here's the thing, though. My Harbor Freioght vacuum pump mentioned 4.3 CFM rate @ 90 PSI. My compressor will go up to 150 PSI, but says it's spec. is 2.7 CFM @ 90 PSI and 3.4 CFM @ 40 PSI (it was purchased to operate a brad nailer). Does that mean my compressor lacks the necessary suds to power the Harbor Freight vacuum pump?
'95 855 auto (sold)
'95 855 auto (sold)
- Has thanked: 2857 times
- Been thanked: 1332 times
Great, thanks.abscate wrote:Checked this one off as solved using the checkbox button next to thread title, on far right
Is your vacuum pump powered by compressed air? Mine is electric.
- E Showell
Yep. But I went out and got. HF vacuum pump and was able to draw vacuum for 10 min heldc. 29 in hg. Left pump connected for another 10 k n. W/ power off and vacuum held. Trying to recharge w/ cans of Arctic Freeze and am having no luck whatsoever. Thoughts?
'95 855 auto (sold)
'95 855 auto (sold)
Do you have all the right valves open?
The needle on the cap of the can has to be screwed in to puncture the can lid, then back out to open the can to the manifold.
The needle valves on the middle port and the low pressure (blue) port need to be open counter clockwise to add Freon
Once you have it right, with Freon on one side and vacuum on the other, Ms Entropy will take over.
- E Showell
Long and the short of it was climate control fuse was shot so the compressor would not run. Fuse replaced and I'll try to do the freon charge this morning, but it is going to be straight from the cans given what I've posted below.
Do all of you guys with the Harbor Freight manifold gauge set recharge from 30 lb. tanks of r134a? The charge hose for that gauge set has a female end and none of the can hoses will fit it, plus I haven't been able to find any kind of adapter. The charge hose appears to be designed to be used with a 30 lb. tank. Did all you guys spring for the 30 pounder? That's a lifetime supply of freon for me.
'95 855 auto (sold)
'95 855 auto (sold)
- 2880 Views
Last post by siboyslim
- 7083 Views
Last post by obayha
- 20 Replies
- 9297 Views
Last post by jsrnsis
- 1971 Views
Last post by sleddriver
- 1584 Views
Last post by Georgeandkira
