1998 v70 is it possible to remove rear axles permanently ?
BlackBart
Has thanked: 967 times
Been thanked: 921 times
Post by BlackBart »
Remove the rear axle? You mean like this?
bronco
Year and Model: 1998 V70
Has thanked: 49 times
Been thanked: 24 times
Post by bronco »
I don't need it done that quickly
bronco
Post by bronco »
So far so good on the stub axles . I got out on the highway and all the weird moaning noises are gone. They were rotational noises I assumed coming from the wheel bearings and are no longer present.
Now whether rear CV axles and or the differential axle bearings were contributing I have no idea. I cant really look at them unless I take the diff out.
I put S70 shocks on in place of the nivomats. I did not buy Tbars I just pushed the sleeves and bushings out of the new shocks and pressed the tbars I had already in . I had some urethane bronco track bar bushings laying about and just clamped them in a vice and took a wood rasp to the outer diameter until they would fit in the eyelet.
I'm sure as several have said I have lost spring capacity but considering both of my nivomats were defective I can't tell any difference . It handles much better because it has functioning shock absorbers now and I think not spinning all that rear axle stuff i'll probably pick up a little mileage.
I probably deleted 50 pounds of weight from the rear between the axles and nivomats that might be helping a little.
Of course I never haul anything with the car so if I put weight in it then not changing springs would be a more obvious issue. I'll drive another week or so then jack it up and take a look for loose bolts or other issues.
I'm going to start searching for parts to do a FWD swap in the next few months but maybe i'll find some backing plates first
Has thanked: 1609 times
Been thanked: 4064 times
Excellent. I’ve cancelled my trip to Boston with my dolly…..
bronco
Post by bronco »
abscate wrote: 20 Sep 2025, 13:00 Excellent. I’ve cancelled my trip to Boston with my dolly…..
I like the white station wagon in that pic!
Somewhere from my travels in Russia years ago I have a picture of a car going down the road ona piece of wood for a wheel
