Found a seller with a used altitiude sensor for $16 plus postage. Also ordered an injector servicing set (seals and screens)
My prostate is getting smaller already.
'98 V70R AWD with high mileage should I plunge?
Should You Buy a 1998 V70 R with High Mileage?
precopster
- Year and Model: Lots
- Been thanked: 128 times
- Has thanked: 2857 times
- Been thanked: 1332 times
Good looking car. I love my HPT.
precopster
Spent some more time yesterday and tore down the front shocks, spring seats & shock mounts which were dated 2003. Also bump stops were falling apart. Passenger side shock absorber had almost no rebound. Swapped in some fresher ones (Quinten Hazel gas assisted struts) from my 2000 V70 but retained the original springs.
Also replaced the sway bar links with Meyles.
Some ham fisted factory tech overtightened the strut bolts back in 2003 (records show dealership servicing) I used an extender and still struggled. When they finally gave in they stretched. I had some camber adjustment bolts lying around so in they went. Some drilling of the knuckle is necessary. I'm using them in the top position only.
precopster
Question: why is the turning circle so ridiculously large on this car? Is something wrong with the front end? Was it designed this way to protect the AWD transaxle?
precopster
Received the altitude sensor from the US which solved the code from that item. Finding the location for fitment wasn't difficult; there was a vacant pink connector just near the right headlight with a bracket with a semi circular cutout to take the sensor. The old altitude sensor had been removed.
Next up the lambda remained lit. My Torque on Android reader couldn't pick anything up so Vol-FCR came out this afternoon. The ECM had some sort of transmission code that wouldn't clear.
Then I probed the TCM and finally read a code about a solenoid 1 problem. Odd because the car seems to drive and shift well enough. Cleared that with Vol-FCR and finally saw the last of the lambda light & hopefully for a while too.
- misha
- Has thanked: 155 times
- Been thanked: 432 times
Nice job!
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
precopster
Plunged in again today and removed the heater core so I could be sure of what's in there. An original Volvo core with logo built in 1999 resided in the HVAC so it may have been replaced when it was under warranty at 2 years of age. It was leaking slightly so it looks like an Estonian heater core from volvonest (eBay seller) will be going in.
I also fitted the new Airtex Wells (OEM) ignition switch from Rockauto. Wow that's a big picture Matt. Thanks for the new auto zoom function
mecheng
- Has thanked: 15 times
- Been thanked: 21 times
What is the symptoms of a bad ignition switch?
1997 Volvo 850 GLT - 190km
Boost is my drug of choice
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
precopster
In my case if the switch was left alone straight after starting I'd have no power to heated seats and indicators. Once the switch is jiggled back slightly the power is restored.
- 19 Replies
- 3730 Views
Last post by obayha
- 1172 Views
Last post by cuhfs
- 36 Replies
- 7976 Views
Last post by bmdubya1198
- 3475 Views
Last post by KurtL
- 812 Views
