Help with powering S60 seat -- Not in a Car Topic is solved
superfr33k
Year and Model: n/a
Been thanked: 2 times
Post by superfr33k »
Started on it tonight, got about halfway before my soldering iron crapped out. This is what I'm planning on when done. yellow line simulating the wire. Does this look right to you?
Bogdan
Year and Model: S60 2.5T-AWD 2007
Has thanked: 2 times
Post by Bogdan »
It looks ok.
Please post if it actually works.
superfr33k
Year and Model: n/a
Its alive! everything is working through the switches. Thanks Bogdan abscate jbeebo wadeatl I'll post some more pics and a video maybe when its finished.
Bogdan
Post by Bogdan »
Yoda Man!
superfr33k
Year and Model: n/a
Finally got around to finishing the seat. I ended up removing the slider mechanism and ordering a shorter cylinder for the office chair base to lower the seat height a bit. Then I used some 1 inch ply and some L brackets to mount it to where the slider had been attached. I had to trim down the metal on the arm that lowers the rear to make space for the L bracket. All in all not too bad once you get it worked out.
darrylrobert
Year and Model: 2001 v70xc M58
Been thanked: 27 times
Post by darrylrobert »
WAIT WAIT are you bypassing the module and powering the motors directly via those factory switches? Are those factory switches rated for high currents, is there a load cutoff to prevent motor burn?
1981 260 GLE converted to 240 M46 after auto box failure
1987 740t auto converted to M47
1997 V70t5 auto converted to M56
1998 V70 factory M56 (parts car)
2001 XC70 factory M58
2002 XC70 auto (parts car)
Has thanked: 1611 times
Been thanked: 4072 times
I’ve already got the hard NO from Mrs Abscate on seeing this picture
darrylrobert
As long as you cut power when the seat is fully reclined thats when the current will rocket to about 10amps, this will over time kill the switches and damage the motor or will have a hot (fire) office seat.
I dont recommend people try this mod in their cars.
darrylrobert wrote: 11 Jan 2021, 05:11 As long as you cut power when the seat is fully reclined thats when the current will rocket to about 10amps, this will over time kill the switches and damage the motor or will have a hot (fire) office seat.
You should able to use the limit switches to cut the motor power easily, look for the little roller switches on the track for angle and tilt. The fore aft motor has an internal limit switch
Both switches are normally open you need to cut the power to the full stopdirection only, so that you can still reverse the seat. That’s left as an exercise for the student.
A different approach by M. Sade is to use the limit switch to discharge an electrical shock to alert the user s/he is approaching the limit.
Joshude
Year and Model: 2005 V50 T5 AWD M66
Post by Joshude »
Hello folks!
Thanks for the great read on this thread. On friday i brought home a new interior for my V50. My old interior is fully manual, the new driver seat is powered. Since no one can help me with information on how to get the powered seat activated (e.g. with VIDA and a subscription, because no one knows the part number for the activation) my idea was to do it this way. Add 12v to the seat and just use it that way.
Now i read something, that it is way more complex with a driver seat than with a passenger seat.
The interior is at my parents at the moment so i can't send any actual pic of the switches, but can i have any success?
If i don't have any chances on get the drivers seat to move i can't install the interior in my car.
Thanks so much!
