Does the 850 have a cooling system bleed valve?
I have just replaced the coolant in my V850, using a 30 percent solution of Nulon anti-freeze/boil & corrosion inhibitor, but now I am having overheating and boiling issues. I am guessing that there may be some air in the system, but I cannot see any air bleed valve. Does anyone know if there is an air bleeding procedure for the 850 cooling system?
- Has thanked: 17 times
- Been thanked: 35 times
No bleed valve...just keep massaging the main hose to the radiator with the car idling and heat on. However, your issue may be a bad thermostat.
- 26 Replies
- 13504 Views
Last post by cn90
- 1025 Views
Last post by erikv11
- 16 Replies
- 6257 Views
Last post by Danonly55
- 991 Views
Last post by rice240
- 3485 Views
Last post by ryanmcgrim
