I have 82,000 miles on my Volvo. How often should the radiator hoses be changed and how do you access the lower hose where it attaches to the radiator?
Thank you for your help.
Raddiator hoses 2002 V70XC
- Has thanked: 17 times
- Been thanked: 35 times
Just feel them to see if they are soft...they should be pliable but not mushy. I would say you're probably good until your timing belt change (105K) anyway. To get at the lower one, you'll have to remove the air babble under there (up front, under the radiator), then you'll see where that lower hose attaches both to the radiator and back around to the engine.
confused_al
- Year and Model: 1996 TLA wagon
I just replaced my low hose after 14 years and 165k miles. I thought I found a crack at the neck, turns out my old eyes mistaken a rubbing mark as a crack. (Discovered after replaced it). These OEM hoses should last a long time if you keep them clean....How often should the radiator hoses be changed...
96 850 Platinum Wagon
98 MB ML320
06 V70
95 850 GLT(RIP)
98 MB ML320
06 V70
95 850 GLT(RIP)
Hi Confused_Al.confused_al wrote:I just replaced my low hose after 14 years and 165k miles. I thought I found a crack at the neck, turns out my old eyes mistaken a rubbing mark as a crack. (Discovered after replaced it). These OEM hoses should last a long time if you keep them clean....How often should the radiator hoses be changed...
Thank you very much for your help.
Zeek
- 1616 Views
Last post by oldp
- 2422 Views
Last post by jonesg
- 7360 Views
Last post by Seaway
- 961 Views
Last post by songzunhuang
- 92 Replies
- 35990 Views
Last post by Sommerfeldt
