Good Evening,
Does anyone know the size of the bolt head on the crankshaft pulley? I'm supposed to turn the pulley to line up the timing belt, etc. when I remove the belt to take the head off (I'm doing the head gasket), but I don't know what size the bolt head is. I know it's larger than 19mm (the largest socket I have in metric), so if someone has any ideas I'd be most grateful.
Also, I've relieved all the fuel pressure from the line, but when I try to remove the line to fuel rail, it really won't budge. I've got the right size wrenches, so I'm assuming I just need to soak it in WD-40 since it's 19 years old, but if anyone else has experience removing that line I'd be glad to hear about it.
Thanks!
GSmith
1990 Volvo 740 8V motor - crankshaft pulley bolt & Fuel line
- billofdurham
- Year and Model: 855, 1995
- Been thanked: 5 times
The crankshaft bolt is 24mm.
I haven't had this problem with the fuel line so can only say use the WD40 letting it soak in for a good while before trying again.
Bill.
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
Previously:
GSmith
- Year and Model: 740 wagon, 1990
Thanks, Bill.
I now need to know how to get the lower half of the timing belt cover off without removing the crankshaft pulley so I can see the lower timing marks. My timing marks are lined up on the camshaft, but I want to make sure the lower marks are okay. I loosened the two bolts I could find, but I still can't get the lower cover off. Anyone?
1990 Volvo 740 wagon - 315k purchased 4/09
GSmith
Scratch that last one, I can see the marks.
However, I'm trying to loosen the timing belt or something so I can get the head off the block. The camshaft pulley nut won't budge, so I can't pull the belt there. Is there any way to get the head off without removing the camshaft pulley?
- billofdurham
You don't need to remove the timing belt completely to take off the head.
The attachment tells you how to do this:
Bill.
Bill.
Previously:
Previously:
- 1411 Views
Last post by DGB47
- 1008 Views
Last post by marcus
- 818 Views
Last post by DRN2001
- 2727 Views
Last post by Williamad33
- 2576 Views
Last post by oragex
