Crankshaft timing pulley position
marcus
Year and Model: S60 2002
Has thanked: 12 times
Post by marcus »
Hello,
What is the procedure to install timng pulley on crankshaf? Lets conisder the shaft was rotated. How to find the coresponding position between the timnig pulley and the crankshaft?
Georgeandkira
Year and Model: '07 V70 + '15 XC70
Has thanked: 79 times
Been thanked: 71 times
Post by Georgeandkira »
Isn't the timing pulley keyed?
Has thanked: 1609 times
Been thanked: 4065 times
It is, unless the splines are ruined. (Very rare)
Clean the splines by pulling a rag with carb cleaner through and you will see there is a thick spline that has to match the wide notch.
It will only go on one way.
marcus
Post by marcus »
Thank you.
