Electronic Throttle Module
S70 2000; failed and was replaced at 65,000 miles during the time of the recall, is again failing at just ~60,000 miles since replacement. Is this normal? Seems to me they may not have fixed the problem to begin with...Anyone else hearing problems with this?
JRL
- Year and Model: Several
- Been thanked: 16 times
Nothing TO fix, they fail.
They can fail at 40K or as long as 135K
FlyingVolvo
- Year and Model: 2000 V70XC
- Has thanked: 51 times
- Been thanked: 74 times
My original was still strong at 150,000 miles, but I decided to swap it out for an XeMODeX unit (remanufactured unit does not fail like originals) as preventative maintenance.
2000 V70XC - 340,000 miles
2023 V60 T8 PE
2023 V60 T8 PE
- BEJinFbk
- Year and Model: '98 V70 R
- Has thanked: 94 times
- Been thanked: 146 times
This is probably one of the biggest mistakes Volvo ever made...smrufo wrote:S70 2000; failed and was replaced at 65,000 miles during the time of the recall, is again failing at just ~60,000 miles since replacement. Is this normal? Seems to me they may not have fixed the problem to begin with...Anyone else hearing problems with this?
There's a whole forum section here that's devoted to the topic:
https://www.matthewsvolvosite.com/forums ... m.php?f=12
Short answer -
Give your great car a version of the ETM that won't die:
http://www.xemodex.com
I remember the original ETMs were from an italian manufacturer and almost always failed, even after the cleaning attempt. I believe they did extend the coverage on affected vehicles to 10 years/200k miles. Might be worth a phone call to the dealership.
'96 854 Turbo
'84 244 FI(sold)
'81 244 CI(sold)
'84 244 FI(sold)
'81 244 CI(sold)
E170_Driver
- Year and Model: bye V70 2.4T, 2001
Exactly the reason why I told Volvo that I would never buy another one. Replacing a wear/tear item with another one shows me that Volvo opted to bypass the right and safe thing to do: Coming up with a PERMANENT fix. When I had my 2001 V70 and learned about this issue, I wouldn't let my family drive in it. I loved my vehicle, but unfortunately Volvo management proved to me that $ was more important to them rather than fixing the issue at hand, bye bye V70. Shame on them and yes other car companies are not better, but in this case it is so evident.
Jan
Jan
Former 2001 V70 2.4T owner
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 20 times
No; the replacements are the same design too.Did Volvo ever use ETM that won't die - during the recall and as original?
If you're out of warranty, you can go the Xemodex option that uses components that won't fail.
'98 S70 T5
2016 Chevy Cruze Premier
JRL
Don't scare everyone, the 02s and newer are a different design and manufacturerjblackburn wrote:No; the replacements are the same design too.Did Volvo ever use ETM that won't die - during the recall and as original?
The 99-01 were made by Magnetti-Marelli
When I was young and rich I owned a few Ferraris
The early 1969-1971 Daytonas had an MM ignition, failed with alarming regularity
In 1972 they switched to smaller Bosch units, they never failed
jblackburn
But that doesn't apply to the model asked about
'98 S70 T5
- 42 Replies
- 8851 Views
Last post by precopster
- 7818 Views
- 1628 Views
Last post by jimmy57
- 931 Views
Last post by jnunorckln
- 12 Replies
- 8461 Views
Last post by Robert Carter
