97 R multiple electrical outages
wolfspiritky
Post by wolfspiritky »
97 R has been sitting for a couple months. It cranks but doesn't start.
First thing I noticed was no hummm when the key is turned on. I have a few extra so, I immediately changed the fuel pump relay...nothing. Then I got to checking and found several other electrical items not working.......heat/ac fan, fuel, boost amp and, tach gauges, radio.
Is there like a "master" relay that could be the cause??
00 S80 T6
97 850R
94 850 GLT-Totaled!
wolfspiritky
MIJ....LEE, I know one of you two must have some idea what's going on.
00 S80 T6
97 850R
94 850 GLT-Totaled!
jblackburn
Year and Model: 1998 S70 T5
Has thanked: 9 times
Been thanked: 20 times
Post by jblackburn »
The common point that ALL of those trace back to is the electrical portion of the ignition switch.
It's about $40, and a pretty common failure point in the electrical system that can cause all sorts of weird stuff to happen. Most of those sound like they could be tied into a problem there.
'98 S70 T5
2016 Chevy Cruze Premier
wolfspiritky
Thanks, I never even thought of that.
Now I need to find the location. I have seached my Haynes manual and repair database. I can find info on the key/tumbler replacement but not the electrical portion.
00 S80 T6
97 850R
94 850 GLT-Totaled!
jblackburn
Oh it's super easy! 10 min job.
Once you crack open the clamshell around the steering wheel (3 Torx screws, I think 4 on an 850), it's on the left side. remove the wire and two screws, pop in the new switch, and button it back up!
'98 S70 T5
wolfspiritky
Ill have to check my "parts Department". I know I have to have one....I have stripped 4 850's.
00 S80 T6
97 850R
94 850 GLT-Totaled!
jblackburn
I hope you bought them dinner first!
'98 S70 T5
wolfspiritky
Well.....the ignition switch wasn't the problem.......
I hate electrical crap!!!
00 S80 T6
97 850R
94 850 GLT-Totaled!
wolfspiritky
This is still an issue. I need to sell this car but, no way I'm going to not running.
Hate to pay a shop to tace an electrical issue...we know where that could lead..$$$$$$$$$$$$$$
Any help here is greatly appreciated. You guys on here have never let me down before!!!
00 S80 T6
97 850R
94 850 GLT-Totaled!
BEJinFbk
Year and Model: '98 V70 R
Has thanked: 94 times
Been thanked: 146 times
Post by BEJinFbk »
wolfspiritky wrote:97 R has been sitting for a couple months. It cranks but doesn't start.
Yes - In fact, there are a couple. 105 and 106 carry a lot of system loads.
But I would start with a voltage drop check between the battery and the B+
connection, first. It's a common failure item on these cars at this age.
To learn more about the "Overload" relays and which systems are handled by
which relays, you can dowload your diagrams and track that info down.
https://www.matthewsvolvosite.com/volvo-wiring-diagrams/
