Alternator / charging system failure 08 XC70
Charging system failure light. Is there anything this could be other than the alternator? The car seems to only be running on the battery power. I'm having to charge the battery daily in order to drive the car.
- regent
- Has thanked: 2 times
- Been thanked: 12 times
Did you inspect the wiring to the generator; make sure to disconnect battery negative if you will use any kind of metal tools. Unplug the connectors and check for loose/recessed pins or corrosion.
There are a couple more checks before you condemn the gen.
It is the voltage regulator and brushholder assembly that fails usually, but I start with the easy stuff.
2015 BMW 335i
2015 XC60 T5 Premier Plus
2002 S60 2.4 n/a - retired
1987 340 DL - retired
2015 BMW 335i
- 20 Replies
- 4050 Views
Last post by bmdubya1198
- 12 Replies
- 11497 Views
Last post by warcraftjunkie
- 13 Replies
- 12504 Views
Last post by Yak
- 584 Views
Last post by pinegrovedave
- 2005 Views
Last post by giegaand1
