Radio problems with S40 2005 PLEASE HELP!!!
cannmj1
Post by cannmj1 »
I recently bought a 2005 S40 and have had several problems with my radio. It was freezing up, which they fixed with a software upgrade..but the problem they can't figure out is my radio volume. When I'm driving and listening to the radio the volume will go down and up randomly (no I do not have speed sensor radio control or anything). I thought it might be a problem with reception but we can't pinpoint it. Has anyone else had this problem?? PLEASE LET ME KNOW!!!
Thanks!
Guest
Post by Guest »
Yes. In Dolby Pro-Logic, my rear speakers do the exact same thing and I'm bringing it in for service on Thursday.
cannmj1
Post by cannmj1 »
Could you please let me know what they do! Apparently they replaced the entire radio system but I am still having problems. Thanks!
Guest
Post by Guest »
I don't know if they gave me the run around but they told me the problem was with the broadcast signals for Dolby Pro Logic and suggested that I only use the 3 channel setting instead.
I guess I agree with that assessment since the same problems don't occur while either listening to a CD or in 3 channel or even in AM.
Then also suggested that I try adjusting the rear speaker equalizer, which I haven't done yet.
Let me know what you are doing.
Thanks.
alderaan
Post by alderaan »
No, they didn't give you the run-around. Dolby Pro Logic can only produce its surround effect when the signal is strong. If it is weak or varies, the surround cuts out. I set my CD to Dolby Pro Logic, but leave my radio on 3-channel. If I know I will be driving where there is a strong signal, I might set the radio to Dolby Pro Logic. Usually I don't bother.
