So, my turbo is definitely in need of a rebuild as it is letting oil pass through and burn and smoke. It is the mitsubishi turbo (not sure the model # but it's from a '90 744). What would be the best for quality and most economical way to rebuild this?
I want to do it myself, but if it involves machining, I do not have any tools to do that. Is there a recommended rebuild kit anyone has found for these turbos? What all do the rebuild kits involve?
Secondly if it does involve machining I was thinking about taking it to a place that works on big rigs and asking them to rebuild it once I take it out of the car. Would this be worth the extra money to have someone else do this?
Thanks!
Travis
Mitsubishi Turbo Rebuild
travis873o
- Year and Model: 1990 740T
precopster
- Year and Model: Lots
- Been thanked: 128 times
This is more than likely a TD04 but just make sure as there is a plate identifying which model it is once you clean the grease off.
There are many resellers of kits out there. Once you have it apart you need to check for shaft and housing damage; not too difficult to do. If you don't have the skills or tools buy some and have a go anyway. There's not that many pieces to them.
Once you place it in the hands of a pro expect to spend much bigger money.
my97volvo
- Year and Model: 91 940 SE, 91 turbo
if you go to this site, they sella center cartridge for around $99......http://gpopshop.com/. I am inprocess of getting a unit frm them myself.
- 2786 Views
Last post by jmscdgn
- 748 Views
Last post by reGSPlmNjn
- 315 Views
Last post by jonesg
- 1179 Views
Last post by rspi
- 12 Replies
- 2967 Views
Last post by FLXC90
