My s70 blew the hose that connects to the engine block from the oil trap ( parts on order) and I now have to clean a bloody mess......
Can someone reccomend a good degreaser that will not damage the rubber seals, wires or anything else on the front of the block? Thx!!
Good engine cleaner....mess to clean up
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
Just about any will do. I like Gunk but just about all of them work fine.
vjaneczko
- Year and Model: 2006 S60R
- Been thanked: 7 times
I pretty much head to AutoZone and grab the cheapest can of engine cleaner. I may have bought two cans when I first got around to cleaning just to be sure, but one should do fine if you have a cleaning schedule.
1997 855 GLT - R.I.P.
2006 S60R - For ME!
2006 S60R - For ME!
- Been thanked: 504 times
Fix the broken hose first, then Castrol Purple Cleaner, then gentle amount of warm water.
Again, you don't want water to enter the engine, so fix all broken parts first.
kiss4afrog
- Year and Model: 850 1995
- Been thanked: 2 times
Best bet is purchasing a can of engine degreaser at an auto parts store and going to a self serve car wash. Just before going in spray down the engine compartment and leave it running while you hose down the engine. Keep the wand a few feet away at all times and have the engine running. Works great.
You can never have too big a Turbo !
I second this... It's what I do...kiss4afrog wrote:Best bet is purchasing a can of engine degreaser at an auto parts store and going to a self serve car wash. Just before going in spray down the engine compartment and leave it running while you hose down the engine. Keep the wand a few feet away at all times and have the engine running. Works great.
Current Volvos:
2004 C70 HPT (wife)
2002 S40 1.9T (daughter)
2001 V70 XC (daughter)
1999 V70 GLT (now dead)
1998 V70 GLT (son)
The other car: 2003 Saab 9-3 SE Convertible (mine)
2004 C70 HPT (wife)
1998 V70 GLT (son)
- rspi
Contact rspi..
If you do the car was hose thing, try to make sure you do it with the car/motor cool or cold. If the engine is at temp, the cleaner may dry before you rinse it off and cause staining.
Do not spray the distributor or much over the spark plug cover. I'm surprised how easy it is for water to get into the spark plug holes.
- 2253 Views
Last post by volvolugnut
- 714 Views
Last post by Olegs855R
- 1315 Views
Last post by 454cid
- 2277 Views
Last post by erikv11
- 1692 Views
Last post by Azik09
