Flashing check engine light after mods!
So a couple days ago my ARD green tune came in for my s70 t5. The tune hasnt made much of a difference thus far because i do not yet have the catless 3" exhaust it was programmed for, and my tcv is old as ****. Tonight i made a MBC and installed it. The car hasnt boosted over 14 or so psi, but at wide open throttle im getting a flashing engine light and the car stumbled. The car does need new wires and a rotor. Am i overboosting or is the ignition system just not in good enough shape to handle the amount of boost its now running? Its a blast to drive, just a bit worried
Matty Moo
- Year and Model: 850, 1996
- Has thanked: 1 time
- Been thanked: 30 times
You need to be at stage zero, 100%. Zero fault of the tune.
Proper plugs, good wires, cap, rotor, vac lines and pcv.
Why are you putting an mbc in with a tune?
http://www.midwest-abs.com
Simplycleanpowerwash.com
1999 s70 Plain Jane.
2000 s70 GLT
2014 Ram
2012 Jeep Wrangler Unlimited
- RobTheModd
- Year and Model: 98 S70T5M
- Has thanked: 5 times
- Been thanked: 7 times
Iirc flashing check engine means missfire.
Get your codes checked.
Mine does it from time to time usually due to one of the plug wires coming up a bit.
- 993 Views
Last post by jbkeene
- 703 Views
Last post by gdict
- 1216 Views
Last post by precopster
- 6363 Views
- 2785 Views
Last post by Georgeandkira
