2002 C70 front end groaning noises when turning
scmedinger
Year and Model: 2002
Post by scmedinger »
My 2002 C70 makes loud groaning and creaking noises when turning the wheels to near the end of the steering limits, like when you are in a parking lot. Does anyone know what I should check or replace first.
Thanks
jimmy57
Has thanked: 5 times
Been thanked: 322 times
Post by jimmy57 »
Look at front of lower control arms, your contact pads may have broken and fallen off. You will notice it by seeing a pair of rivets with the spot between marred by the spindle contact bar wearing the control where pad should be. Harmless but noisy.
mikealder
Year and Model: V70 2000
Been thanked: 13 times
Post by mikealder »
Smear a little grease on to the steering limit stops, this tends to stop some of the noise - Mike
kiss4afrog
Year and Model: 850 1995
Been thanked: 2 times
Post by kiss4afrog »
That part of the control arm where there should be a plastic rub point is the little bulge just below the ball joint on the right in the picture. A little grease will usually take care of a noise you'd get when turned all the way left or right.
Control arm, lower.jpg (12.51 KiB) Viewed 2246 times
You can never have too big a Turbo !
jblackburn
Year and Model: 1998 S70 T5
Has thanked: 9 times
Been thanked: 20 times
Post by jblackburn »
If that doesn't solve it, worn out tie rods made a nice loud "pop" when I approached the limits.
'98 S70 T5
2016 Chevy Cruze Premier
scmedinger
Thanks for the replies, is will try the suggestions and post back.
Ben850
Been thanked: 7 times
Post by Ben850 »
Just another noise making option to consider, the spring seats made a creaking sort of noise on mine when they were bad.
The steel sleve was staying in place while the seat was turning around it. Not so much a "groaning", but a creaking.
1996 850 Turbo Wagon White.
1994 850 N/A Wagon Black.
1997 850 Sedan Black.
1996 850R Wagon White.
scmedinger
Creaking is probable a better word to describe the noise. The noise will happen even when sitting still and i just crank the wheel all the way to the left.
Ben850
Post by Ben850 »
Yeah, that sounds like a spring seat, or both.
I want to add that my '93 control arms are the aluminum ones with a different bump stop, but I have heard what sounds like a groan when maximum travel is reached, i. e. a tight slow turn into a parking space.
Ben850
Post by Ben850 »
Here is an old thread that explains the bump stop noise with the remedy.
https://www.matthewsvolvosite.com/forums ... 3&start=14
