Hello all, i am back once more with another issue for my 96 850 turbo, several days ago the Check engine light came on. I drove to advance and they scanned it to determine it was P0117 or engine coolant temperature sensor. I figured i would replace it several days later, as i was driving home later that evening the car began to rev higher when i did not tell it too, within another 2 minutes, the car was idling at 2k RPM and if i dropped it into neutral it rev'd to 4k, i shut my car off and when i went to turn it back on low and behold it would not start. Is this a typical symptom of a failed coolant temp sensor? it starts after being left alone and initially runs, i have not gotten it to fail again as before but would like your input the part i will be ordering is
http://www.ipdusa.com/products/5726/114 ... ure-sensor
Is this part correct to fix my woahs?
High revs, car wont start after driving p0117 code
anmartin44
- Year and Model: 1994 850 n/a
- Has thanked: 2 times
- Been thanked: 2 times
Sounds pretty typical of ECT. Make sure you get an OEM one as the aftermarket one are hit or miss. Probably should replace you thermostat as well .
1994 850 na green 187k on body, 275k on motor(backwards?), unrestricted airbox, 960 TB, persus wheels, Lowered, IPD poly upper and trans mounts.
1974 144 k-jet m40 satin black, 250k on body, 25k on rebuilt motor(running...usually)
- 2762 Views
Last post by MadeInJapan
- 37 Replies
- 8611 Views
Last post by songzunhuang
- 2701 Views
Last post by dono
- 3148 Views
Last post by jreed
- 23 Replies
- 3568 Views
Last post by DaveenBavari
