06 S60 Low coolant light in extreme cold weather
toxtreme
Year and Model: 00S80, 05XC90, 06S60
Post by toxtreme »
So I started my S60 this morning (-5 deg) outside and car was on a slight decline (engine on downward point in parkinglot) and the "low coolant" red triangle appeared, I let it run for like 1 minute then turned the car off, waited about 30sec and restarted car, light didn't come back on, I drove the car for about 35 minutes to work and checked the level, it was about 1/2" above min, I see on other google searches that people mention that the coolant may be contracting in the extreme cold weather, just wondering if anyone else has encountered this issue and if it is normal and what I should do?
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
it is contracting however the level is a bit low anyway, you may add a bit of distillate water or coolant mixture about 5oz
it doesn't hurt the engine to have the coolant low for a moment
vtl
Year and Model: 2005 XC70
Has thanked: 130 times
Been thanked: 686 times
Post by vtl »
Add VOLVO coolant. It comes in concentrate, mix it 50/50 w/ distilled water.
toxtreme
Post by toxtreme »
So I'm no where near a dealer to get Volvo coolant, is there another type of coolant that I can use or should I just put distilled water in?
Rocky
Year and Model: 2003 xc70
Post by Rocky »
Same thing happened to wife when in middle of nowhere she got some no name coolant.., it was at minimum so barely needed to add anything.
I would just go to parts store buy something "ok for Volvo" name brand type.
toxtreme
Post by toxtreme »
Thanks, I did just that, I even called Volvo dealer and asked them what to do, he said O'riely Auto Parts carried Zerex G-05 and that it would be fine to put that in, seems to be working fine.
oragex
Post by oragex »
I'd keep an eye on the coolant level. if it drops a little it might be leaking somewhere. if mileage is higher than 150k, it'd be a good idea to check the water pump for leaks.
