S80 turn signal relay
S80 Turn Signal Fuse Numbers
Guest
I have a 99 S80 & am trying to identify which relay operates the turn signals so I can replace it. Can anyone help?
Guest
I repaired this per the post from Nov 6 2005. Pull # 21 & 22 fuses to reset module. Everything works now. Thanks.
DMP
Thank you a thousand times for the information about pulling the 21 and 22 fuses to reset the steering column module. We have a 99 S-80 and the turn signals along with the rest of the contols on the steering column quit working. I was getting ready for another big repair bill but your advice worked. I'm very curious why this happened, any ideas? Is this an idication that the module is going bad?
Tried to use this fix on my V40, unfortunately the fuses aren't numbered in either of the fuseboxes
Can anyone offer some assistance here? I have no turn signals at the moment and I'm worried I'll cause an accident on my way home from work!!
- billofdurham
- Year and Model: 855, 1995
- Been thanked: 5 times
The original post was for the S80, so may not be relevant to your vehicle.
You do not give the year of your V40 but I have checked for the 2000 and 2004 model years and the turn indicators are covered by fuse #6 in the passenger compartment fuse box.
Bill.
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
Previously:
- 3244 Views
Last post by yagger
- 741 Views
- 4431 Views
- 1076 Views
Last post by kyngofpop
- 762 Views
Last post by abdomar528
