I need some help from you guys regarding the order of replacing the front suspension on the 2002 V70 T5. I am using the FCPEuro package - Sachs struts/spring seats/bearings, Lemforder controls arms, Meyle outer tie rod ends/sway bar end links. What's the best order in R/R the front suspension? Thanks...
Dos_volvos
2002 V70 T5 Front Suspension Replacement
dos_volvos
- Year and Model: 2004 XC70
- Has thanked: 2 times
precopster
- Year and Model: Lots
- Been thanked: 128 times
Can you please rephrase the question? Do you want to know which order to replace things in or which are the best parts for the car?
dos_volvos
Sorry for the confusion. I have the aforementioned FCPEuro front suspension parts in hand. I would like to know what's the best order in R/R the front suspension e.g. Control arms then struts or struts then control arms? Or does it even matter which order when replacing the parts. Thanks.
precopster
You'll probably find it easier to remove the strut first and then remove the control arms. By removing the caliper and brake disc you can easily pull the hub/knuckle assembly together with the control arm so you can work on the difficult task of ball joint removal on the ground or on a bench.
dos_volvos
Thanks precopster for the reply.
- 12 Replies
- 3362 Views
Last post by RickHaleParker
- 12 Replies
- 5300 Views
Last post by dux02v70
- 2235 Views
Last post by rubbersidedown
- 15 Replies
- 3444 Views
Last post by dosbricks
- 14 Replies
- 8549 Views
Last post by vtl
